Extra capacity oil pan
It seems pretty affordable but that's what I'm afraid of. I'm curious of any fitment issues.
351M info below. The 351M guru to ask about a quality high capacity pan. http://www.tmeyerinc.com/
History of the Ford 351M
Rumors & Myths
351M/400 Performance Build Up
Bubba's M-Block Ford V8 Workshop
M-Block 351M/400 Parts Reference
As far as that pan in a rear sump set up working...do you have headers or the more common 2 into 1 Y that makes the dvrs side exhaust come over to the pass side then exit in a lone pipe? I ask because usually the dvrs side passes thru the area the bigger pan will be in.
Good reads. https://www.ford-trucks.com/forums/3...ification.html
https://www.ford-trucks.com/forums/7...ification.html
https://www.ford-trucks.com/forums/9...orrection.html
More great info.
http://www.garysgaragemahal.com/351m-and-400.html click on the "Oiling System Mod's" and get your read on.
And again see Tim Meyers mentioned all over the place.
Melling oil pump is what you want. High volume / high pressure pumps are not necessary for a truck motor unless you're racing it.
Even a 500 hp 351C/351M/400 wouldn't need a fancy oil pump.
