correct oil pan
Old Nov 7, 2007 | 05:19 PM
fomocojake1's Avatar
fomocojake1
correct oil pan
Im going to install a 351w in my 78 4wd. The motor im using is a 84 2wd, will I need to use a 4wd pan or will the 2wd work ? Thanks for any info
Old Nov 7, 2007 | 05:44 PM
Mil1ion's Avatar
Mil1ion
Rear sump & Oil Pickup
Old Nov 7, 2007 | 06:15 PM
fomocojake1
Hey Da Man, I kinda dont know what you mean. Could you explain your thoughts of wisdom a little further? THANKS
Old Nov 7, 2007 | 06:49 PM
Mil1ion's Avatar
Mil1ion
The 4x4 requires a rear sump pan because of the cross member.
The oil pan on a 4x2 is located at the front so the drain hole and pan clearance are comprised on 4x4.
Rear sump oil pan and Rear sump oil pump pickup are required.
Check out E-series Vans for what you need for OEM application
Old Nov 7, 2007 | 07:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All the 1975/91 Econolines use a rear sump pan and pickup tube.
Engines used: 300 I-6, 302 (first offered in 1979), 351W, 351M/400 (1980/82 only), 460.
Old Nov 7, 2007 | 09:25 PM
masterbeavis's Avatar
masterbeavis
weren't all pickemup trucks after 83 rear sump? Snag the power steering bracket and saginaw pump off of the van too, so that you are assured clearance at your steering pump.
Old Nov 8, 2007 | 08:15 PM
fomocojake1
Went out to my garage to look at the 84 351w, yes it is a rear sump, thanks for your response.
Old Nov 9, 2007 | 11:11 AM
loudfords's Avatar
loudfords
And just for reference, the rear sump pan on the 80's trucks will fit ok in a 2wd, just don't nail a big bump at speed. I've been running a rear sump pan for about 4 years now in a 2wd. It's also much easier and neater to change the oil than on the front sump pan.
