1995 4.9L not reaching operating temp
Old Dec 24, 2017 | 08:42 AM
87944turbo's Avatar
87944turbo
Have a question, I just replaced the WP and TStat on the truck and now finding that it takes a very long time for the truck to come up to temp. Previously, it would come up to temp in a few minutes. Now, the needle barely enters the very edge of the actual temperature range over the same time/distance. Is it possible for new a thermostat to fail open? The one I put in was just your garden variety from Advance Autoparts.
Old Dec 24, 2017 | 09:05 AM
Jklnhyd's Avatar
Jklnhyd
All too common these days to have a brand new thermostat that is bad.
It is a pia, but you should check them in a pan of water on the stove with a thermometer before installing.
Old Dec 24, 2017 | 11:19 AM
vjsimone's Avatar
vjsimone
This is how you spell "Motorcraft"
Did you put in the same temperature rated T-Stat as the one you removed?
Old Dec 24, 2017 | 11:36 AM
timbersteel's Avatar
timbersteel
^^^^^^ Always use Motorcraft when it comes to the Cooling System and the Ignition system.
Old Dec 24, 2017 | 01:09 PM
'89F2urd's Avatar
'89F2urd
Why did you replace the thermostat initially? Do you still have it?
Old Dec 24, 2017 | 04:29 PM
byronbgs's Avatar
byronbgs
Maybe the temp sensor failed?
Full Size Image - Fixya
If you bought a Fail safe thermostat and it locked in the open position you will have to remove it to check and replace it again.
Old Dec 24, 2017 | 04:39 PM
87944turbo's Avatar
87944turbo
Thanks for the comments. I'll pick up a Motorcraft thermostat this week. I replaced it since I had a leaking WP and was right in there anyway and with all the coolant drained it seemed like a good idea at the time. In hindsight maybe not since the other one seemed to be working fine. I'll be sure to test the new one. I guess I could throw the one that's coming out in some hot water and see what happens. I talked to some guys at a shop and they suggested that it might have slipped when I installed it, but they said that usually when that happens the housing will crack when you tighten the bolts and so far as I can tell that didn't happen. I guess I'll know more when I pull it off.
Yep, it's a 195 DEG thermostat.
Sincerely appreciate that, been away from Fords for about 20 years, so go to know.
Old Dec 24, 2017 | 05:01 PM
vjsimone's Avatar
vjsimone
Usually never hurts to replace a thermostat, especially when your draining the coolant anyway....
Justus6.0L
Mar 8, 2017 05:58 PM
obscurity
Jun 10, 2013 10:32 AM
david00f150
Dec 9, 2010 08:35 AM
JoeVB
Aug 14, 2005 02:58 AM
TwoF150
May 4, 2003 06:56 PM
