Thermostat
Old May 3, 2003 | 10:18 AM
TwoF150's Avatar
TwoF150
Thermostat
I recently purchased a 95 F150 6 cyl. The temp rises gradually to about 1/4 of the range and I am assuming that the thermostat has failed in the open position. No sure how long it has been this way but will replace it soon.
Any problems that this could cause. Running too rich, running at lower than designed temps? Any difference in thermostats out there?
Old May 3, 2003 | 11:55 AM
steve83's Avatar
steve83
Thermostat
Sounds perfectly normal. No problem. If you're worried, get a Haynes manual and test the thermostat & gauge temp sender by the printed procedure, but I'd say not to worry about it.
Old May 3, 2003 | 04:18 PM
mrak's Avatar
mrak
Thermostat
pretty normal - I agree. Mine stops on the O in NORMAL. Sometimes the R, but just barely off of the cold mark.
Old May 3, 2003 | 07:52 PM
TwoF150's Avatar
TwoF150
Thermostat
The vehicles that I have owned previously came to mid range then opened and the water was circulated and the temp guage went down a little and back up.
If you guys say this is the normal operation for this vehicle it is one less thing to fix.
Old May 3, 2003 | 08:32 PM
jim henderson's Avatar
jim henderson
Thermostat
Sounds normal. Keep in mind our gauges are not laboratory quality. All they can do is tell you...
Cold, cool, wamr, hot, really hot. The reading is all relative. I would only worry if it regularly rode at 3/4 or more. Or, if it takes half an hour of freeway driving to get to 1/4, then I might suspect a bad thermo.
If the heater is running within say 5 minutes of starting and the heat is good, then you are probably fine.
Good Luck,
Jim Henderson
Old May 3, 2003 | 08:41 PM
Duderoy's Avatar
Duderoy
Thermostat
I would change the thermostat either way. Every used vehicle I buy that's the first thing I do is change the thermostat. We're talking about $7.00 and the coolant probably needs flushed anyway. VERY cheap peace of mind.
Old May 3, 2003 | 09:18 PM
TwoF150's Avatar
TwoF150
Thermostat
The heater works fine. I am only concerned if the engine is not running at the proper temp or too rich for too long due to lower temp.
Old May 4, 2003 | 12:39 AM
Turbo2000's Avatar
Turbo2000
Thermostat
I had a thermostat get stuck in the open position, and my truck wouldn't even warm up enough to show in the NORMAL range. From what I understand, if it is stuck open, it will take a long time to warm up, if it ever does warm up, and if it is stuck closed, it will warm up to a higher than normal temp, but I would say that if your temp gauge is showing somewhere on the "O" or "R", it is fine.
Old May 4, 2003 | 05:28 PM
Torstein's Avatar
Torstein
Thermostat
Is the reading around 'o' on a gas or diesel?
Mine is never leaving 'N' in "NORMAL" in a NA 7,3 Diesel ('93)? I guess that is correct for a Diesel.
Old May 4, 2003 | 06:56 PM
eckart's Avatar
eckart
Thermostat
My 88 F150 5.0 runs just below the N of normal. I just put a new 195 degree thermostat in it and it still runs in the same spot. So I guess thats alright
