Operating Temp
Old Dec 8, 2010 | 01:26 PM
david00f150's Avatar
david00f150
Operating Temp
Whenever the outside ambient temp is below 50 degrees my truck never reaches operating temp. When it is a warmer day it does okay. I believe the thermostat is just stuck open, but I wanted some other opinions before I changed it. This is my 1st diesel and haven't worked on many of them. Just used to working on gas engines.
Old Dec 8, 2010 | 01:48 PM
_Me2_'s Avatar
_Me2_
I believe you're right.
Old Dec 8, 2010 | 02:19 PM
sammy77's Avatar
sammy77
How are you checking operating temperature? If the temp doesn't climb over 190 it's probably stuck.
Old Dec 9, 2010 | 08:20 AM
RigET's Avatar
RigET
Thumbs up
I noticed last week on an 60 degree day I was running 180 degrees down the highway. Changed the thermostat and now on a 40 degree day I come up to 190 around town. I obviously had a bad thermostat. Hope that info helps.
Old Dec 9, 2010 | 08:35 AM
69cj's Avatar
69cj
Luckily the t-stats seem to be more prone to sticking open rather than closed.
