460 Ignition
Old Dec 21, 2017 | 05:24 PM
Coutu's Avatar
Coutu
460 Ignition
Got a free DUI ignition, model 32720BL. I'm not very familiar with these or ignitions in general that deviate from stock. My question is, what else do I need to go with this unit? I was assuming a coil, but on the Summit website (https://www.summitracing.com/parts/dui-32720bl), it says OEM style but electronic, so I'm going to have to ask you guys before I order anything and waste time/money what exactly this means?
Any help is appreciated
Old Dec 21, 2017 | 05:57 PM
mrollings53's Avatar
mrollings53
You should have also seen that it is NOT computer controlled compatible. It's useless in your truck unless of course you also want to swap to a carb, and a manual or C6 transmission.
Last edited by mrollings53; Dec 21, 2017 at 05:58 PM. Reason: Forgot that he got it for free
Old Dec 21, 2017 | 07:28 PM
Coutu's Avatar
Coutu
It’s an 87’, so yes it is carbureted and I do have a C6. Should have mentioned that in my OP.
Old Dec 22, 2017 | 11:32 AM
mrollings53
Well, it's just a Duraspark distributor, so go find an old truck with the same system. Grab everything connected to the distributor. Note where the wires go on the ignition control box. Then splice the box into your trucks wiring. Plug the dizzy in, and set base timing.
Old Dec 22, 2017 | 12:08 PM
Coutu's Avatar
Coutu
Yeah I called the place and they said the stock components will work. Just being safe and not trying to waste money. It’s cost me enough as it haha.
Thanks for for the help; appreciate it.
Old Dec 22, 2017 | 06:31 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Scotty, The Mad Porter sells recurved 460 distributors and could probably give you a real good idea of what you are getting into.
Parkland Performance Auto Machine - Home
Duraspark is probably right. I think the 460 swaps with the 351M/400.
Lilryan
Nov 30, 2012 12:21 AM
Myfreeford
Electrical Systems/Wiring
Sep 27, 2012 03:01 PM
pin04005
Jun 8, 2011 07:08 AM
Melchiah
Nov 1, 2005 03:19 PM
javi2001
15
Jul 3, 2003 05:03 PM
