87 460 ignition upgrade
Mallory 6856M Mallory Hyfire 6EZ/6EZL Digital CD Ignition Systems
or do i start with a MSD 6A box and then add a dizzy later?
do i want to swith to an HEI setup?
any help on where to start would be much appreciated. i know when i had my mustang, i noticed a huge difference when i added a MSD 6A and better coil. so i know a good ignition system makes a big difference.
thanks
ryan
Personally, unless you are racing, I'd stay with the stock system and spend your money on a good set of wires, cap/rotor, and plugs. The stock ignition systems on these vehicles put out plenty of spark.
To improve your reliability, if your TFI module is still on the base of the distributor, move it onto the firewall or fenderwell, using an aluminum heatsink (and wiring harness) from a later-year truck.
On my 87', I went w/ keeping my stock distributor, but upgraded to a brass cap & rotor, a 60K volt/ .45 Ohm resistance Pertronex HV Coil, MSD Superconductor wires & Motorcraft Copper cores gapped up from stock .045 to .052. Higher voltage coil allowing a larger gap, therefore increasing the size of your spark kernel doesn't leave much if any unignited fuel for an ignition box to take advantage of. Bumped up my base time to 16BTDC w/ 87 octane. 89 octane on long hard road trips or heavy hauls. 16BTDC is not a must. Anything above 10BTDC will show improvement & no significant return above 16BTDC for an otherwise stock engine.
If you think you may want to go w/ an ingition box later, make sure the Ohm rating of the coil you choose is compatible. The Pertronex HV series @.45 Ohms syncs w/ their ignition box as well MSD's & Mallory.
Upgrading your ignition system, along w/ increasing your base timing is a relatively cheap date, that improved performance & MPG (If you can keep your foot out of it after the Mod) simultaneously.
See Link: http://www.f150forum.com/f10/about-i...ng-bump-53159/
I'm currently running all stock, but I have bumped up my base timing to 10 deg. BTDC (once I unfroze the distributor that hadn't been moved in 22 years) so I will have to try a bit more advance and see what happens. Did you notice that you could advance the timing further with the hotter ignition or did you make all of the changes at the same time?
I'm currently gettin 10-11mpg in mixed driving which is better than my 1979 Chevy K20 single-cab got.
I'm with you on the all-brass contacts too, but they seem to be harder and harder to find as the years go on.
No. Not really. As mentioned in the link, upgrading ignition components & bumping the base timing, are two separate modifications that compliment each other.
The Ignition system upgrade is to allow the plug gap stretched to provide firings w/ consistent, adequate spark kernel size to more fully utilize the fuel being provided. A side benefit you will likely experience is a notably lower hydrocarbon reading when smog teated.
The timing bump moves/adjusts the moment of actual firing in the piston's cycle. Hard to explain, but although your actual compression ratio obviously does not change, your rate of compression is increased. A by-product of increasing the rate is will be a combustion chamber thermal increase (Copper Core plugs are far & away best suited for this). Add to that, a reduced wicking effect resulting from full use of fuel, you have a recipe for the possibility of ping, which can be addressed directly in multiple ways.
The Two most effective, is minor coolant system modification of a 180F thermostat &/or wick effect replacement by upping the octane level of your fuel. Neither of these are usually required at or below a 14BTDC base timing advance & increasing octane rating of your fuel should be the last resort. 15-16BTDC is usually where these two methods may need to be considered.
All this being said, the Ignition system upgrade/ Timing bump is the only Mod I'm aware of that will simultaneously increase performance & MPG's. Feel free to PM me w/ any questions during your progress, but I think my link should has a lot helpful info for you.
