i am thinking new ignition
Old Oct 30, 2005 | 11:19 PM
Melchiah's Avatar
Melchiah
well i got the stock FoMoCo distributor on right now but i have heard some good stuff bout the mallory uni-lite but money is an issue and what would be the best bang for the buck, and second what is compatible with the ignition box i got in there from ford i don't mind wiring either but could do with out it cause i do it at school all day long edit i would also like it to be hei so could i make the unilite hei some how
Old Oct 31, 2005 | 12:27 PM
Brad Johnson's Avatar
Brad Johnson
Model, year, application, etc. Need more info.
Brad
Old Oct 31, 2005 | 01:34 PM
turbo2256's Avatar
turbo2256
The ignition box holds it back more than the distributor. unless the dist is fried
Old Oct 31, 2005 | 06:40 PM
Melchiah's Avatar
Melchiah
i got a 77 w/ 460 and it has a larger cam and also a c6 but i am looking into it and i would like to get rid of that ford ignition box
Old Nov 1, 2005 | 12:56 AM
monsterbaby's Avatar
monsterbaby
I personally don't like the mallory unilite dist. the little optical sensor that triggers it are prone to going out, and that little sucker costs $90 to replace. I had one, and had to replace it twice in one year second time threw the dist away, and bought a MSD dist, and never looked back.
The Mallory ignition boxes, are ok although I run the MSD stuff on mine personally.
Old Nov 1, 2005 | 05:12 AM
turbo2256's Avatar
turbo2256
My only gripe with MSD is they dont allow for less distributor advance than the black spacer. I have to make thicker ones.
Old Nov 1, 2005 | 09:28 AM
Brad Johnson
The DuraSpark ignition is pretty darn good for a factory unit. A good rebuilt distributor and new control box will keep a mostly-stock engine motoring along happily, provided you outfit it with good wires and properly gapped plugs.
Brad
Old Nov 1, 2005 | 11:20 AM
turbo2256's Avatar
turbo2256
Brad
Motorsport at least used to have a better duraspark II modual of course the old Chryseler units mated up to the Ford distributor did about the same thing.
Old Nov 1, 2005 | 12:34 PM
Melchiah's Avatar
Melchiah
quick question what does the pertronix ignitor II system do differently than a MSD or Mallory perf distributor
Old Nov 1, 2005 | 03:19 PM
airharley's Avatar
airharley
The Petronics system is an add on if I am not mistaken. It sits under the cap and replaces the old points with a magnetic system. Very good for retaining a stock appearance. The "II" is a billet design with their own style housing. I have looked at a bunch of different options concerning my distributor. I didn't like the price or function limits some brands placed on their products. I did find a distributor that is largely stock but also has some really good potential to make life easier with parts sitting on the shelves of most auto stores. I bought a GM HEI style system off of ebay for $110. I can custon tune the entire system and replace all of the wiring with 2 wires now. One for the tach and the other is a power wire. Very user friendly and easy to get parts for. I had problems with a miss that I couldn't get rid of before. Now I don't suffer from that. Not to mention that most coil manufacturers have high voltage coils made for GM HEI's.
