i feel extra stupid for not grabbing my sub and amp outta my titan when i traded it in.
how those 2.0 piggy back fox's ride?? I saw that pic in the other stereo thread, i guess that could've been an old pic lol
2.5s up front, 2.0s in the rear.... They are heaven. Best upgrade I've done by far.
That package would work, although there's a 10" wedge that some guys were using behind the back seat, ad $100 amp and you're cheaper/better off than that package.
Just make sure your amp had speaker level or high level inputs. Makes the install a breeze.
oh ok, yea I've seen those a lot. they look horrible, but if its behind the seat then its all good. Thanks!
Pull the weather strip sell out and look in between the plastic trim and the door pilar with a flashlight. I'm not sure XL's have the plug. My XLT has it. If you have it you will see it.
I pulled back weather strip. See seat belt and some sort of cable wrapped in a cloth tape? Not sure if that's what your talking about or if that is for something else?
You should be able to see a wiring harness with nothing plugged into it, if you have it.
IMO you're much much better off buying this enclosure and the sub driver of your choice with an aftermarket amp. The factory sub is not worth the money if you're starting from scratch.
