Offroad & 4x4
Winch electrical spec question
Old Dec 16, 2017 | 10:37 PM
Sparky83's Avatar
Sparky83
Not sure if this would be better in the electrical or offroad 4x4 section... but considering alot of you offroaders use winches on your rigs maybe you can help me understand something... I got a winch for my truck and when im reading the manual for it (shocking i know... someone read the instructions.. shame on me..) it said the winch has a 300amp draw under the 12v dc section... but the circuit breaker module that came with the winch has only 3 50A breakers setup in parallel... with the calculation i learned in skool.. this puts the breaker unit rated at only 150A...
if the manual calls for 300 amps to function shouldnt i need 300amp breaker?? or am i completely missing something here...
Old Dec 17, 2017 | 05:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would say the 300 amp draw is full load draw.
normal draw is going to be closer to 75 or 100 amps
Old Dec 17, 2017 | 09:52 AM
Sparky83's Avatar
Sparky83
but wouldnt that still require a 300 amp breaker to be able to pull the 300am at full load?
Old Dec 17, 2017 | 10:28 AM
Nothing Special's Avatar
Nothing Special
Yeah, that seems wrong to me. There are slow-blow breakers that will allow more amperage for a short period of time (like getting a table saw up to speed) but will blow if they are over the trip point for too long. But I don't think that would work for a winch (they don't need a lot of current to start, but the current draw goes up as the load and heat increase).
It seems to me you will be blowing breakers long before the winch motor gets to its rated draw.
Old Sep 9, 2018 | 04:53 PM
Flip4ford's Avatar
Flip4ford
If you ask me I say bring marshmallows there's gunna be a fire-- That setup seems to be for a smaller ATV sized winch? Larger vehicle sized winches have 4 -5 or even 6 breakers I did find this on a winch website - 120amp for a 0lb pull--- 440 amp for a 10,000 lb pull.
Old Sep 9, 2018 | 11:11 PM
Sparky83's Avatar
Sparky83
hasnt had a fire yet... worked pretty well too... pulled a building with it... along with a few other things so far...
Old Sep 13, 2018 | 12:50 PM
Nothing Special
Old thread here, but using too small of a breaker isn't going to result in a fire, just in tripping the breaker LONG before the wiring gets hot enough to burn. Fires are a risk when the wiring is too small for the breaker, not the other way around.
Slug-O
Apr 12, 2010 07:50 PM
Lariat02
May 27, 2008 05:27 PM
Scout
Apr 26, 2007 09:31 AM
RomerB2
Jul 26, 2005 01:58 AM
frdtrkman
Jan 10, 2004 11:28 AM
