Do these hinges get bolted directly to the side of the cowl, or should there be a thin fiber(gasket paper) washer on the studs to protect the paint on the cowl as they are tightened?
Thanks, Ray. I didn't think about a leak problem, a thin washer of gasket paper would probably be a good idea then. I have some 1/64" gasket stock. I wouldn't think that would be thick enough to cause an alignment issue.
Mark
No pictures yet.....motor back in and running ...completely painted and ready for assembly......may wait til spring ....unless I really get motivated!..... lol
