flat head six oil galley plug
I tried to remove the pipe plug on the oil galley right in front of the distributer, and stripped out the allen wrench hole. We are thinking the sending unit was maybe screwed in rear of the oil filter in the hole above the oil pressure spring and plug. Would that plug read engine oil pressure ? Has anyone used that port before? We are going to hook up a oil pressure gage temporarily to start up the engine. It would be easier to rout a wire back there than try and remove the plug. Forgot to say the engine is a flathead six. I hate to dill out the plug and use an easy out for fear of getting metal shavings in the oil galley. Dale
Got it out. I decided we'd better put the the sending unit in the proper spot. Was just about ready to pull the welder over, but decided to try mechmagcn's idea. I knocked in a screw extractor without heating it up and it just barely came out before the easy out broke. Thank's for the advice.
z28tito
07-29-2016 12:55 PM
