Ford C6 trans how to manually put in 3 ?
I have a e350 1996 300 cu since a few month.
I have read somewhere that the c6 is 3 speeds + reverse. I can clearly feel the trans shifting from 1 to 2 but I have never really felt 2 to 3.
Some people mention doing it manually but on my shifter l only have P R D 1 2 no 3
It is also my first automatic trans so I am quite clueless.
In a C6 your D is the 1,2,3 progression. If you select 1, you are in 1st gear fulltime with no shifting out. If you select 2, you begin in 2nd gear and when appropriate it shifts to 3rd. If you come to a stop, it begins again in 2nd. This can be helpful for soft starts in snow or sand.
If you are in 2, this also has a "hill-holder" feature that will not allow the vehicle to roll back even if you take your foot off the brake.
1st to 2nd is done with a band applied and can be more noticeable than 2nd to 3rd which is a clutch applied for the shift
68murc
09-12-2007 05:45 PM
78_ford_F150
10-24-2004 11:36 AM
TNTsF-250
05-03-2004 11:01 AM
