Steering column question
Old Dec 11, 2017 | 05:26 PM
Gwilkrrs's Avatar
Gwilkrrs
I am working on a 51 f1 and need a steering column.
Any suggestions? I see ididit, flaming river, and some others..... I want tilt with column shift key or no key
Not sure if any have used any and have pros and cons
Old Dec 11, 2017 | 07:39 PM
Rusted56's Avatar
Rusted56
Do your research first....This study seems to suggest that you get what you pay for, and
you probably don't want to go on the cheap with steering. Good luck.
https://www.lvvta.org.nz/documents/i...ng_Columns.pdf
Old Dec 12, 2017 | 02:30 PM
petemcl's Avatar
petemcl
Didn't you post this question before?
https://www.ford-trucks.com/forums/1...-question.html
Old Dec 13, 2017 | 06:35 AM
GreatNorthWoods's Avatar
GreatNorthWoods
You can't go wrong with an Ididit column. I have a column shift tilt in my 53 Chevy. Works well and I'm happy with it.
Old Dec 13, 2017 | 10:46 AM
Gwilkrrs's Avatar
Gwilkrrs
great info- thanks.
I am noticing they don't come with neutral safety switches or back up switches........
what to do about that?
Old Dec 13, 2017 | 10:48 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
great info- thanks.
I believe the backup light switches are usually on the transmission, for vehicles that came with them.
Old Dec 13, 2017 | 12:08 PM
petemcl's Avatar
petemcl
I can't remember what trans you have but on my 4R70W both are in the Range Selector on the left side of the transmission and are wired into the Baumann controller. You run your wires from there to the backup lights and starter solenoid. Both of those circuits are included in the Ron Francis Bare Bonz fuse panel. The Lokar shifter also has a neutral start switch but you don't need to use it.
Old Dec 13, 2017 | 01:54 PM
GreatNorthWoods
great info- thanks.
Lokar has you covered. I have a neutral safety switch on my 700-R4 but do not use or have back-up lights.
Old Dec 13, 2017 | 08:51 PM
Gwilkrrs's Avatar
Gwilkrrs
Ok I feel better- I am using a built 200r4 so I will look into that-
I was looking and wasn't seeing the neutral safety
Thanks
Gwilkrrs
Dec 11, 2018 06:52 AM
78 PEB
Jul 12, 2016 02:25 PM
dwrestle
Sep 26, 2010 09:00 AM
eman92082
Jan 3, 2008 07:55 PM
