Steering Column question
Old Sep 22, 2010 | 10:19 PM
dwrestle's Avatar
dwrestle
I was wondering if you guys knew if a 92-96 steering column could be made to work easily enough in an 83 truck, or maybe even a 87-91?
Old Sep 22, 2010 | 10:25 PM
dwrestle's Avatar
dwrestle
87-91 column in an 83 that is, not 92-96 column in an 87-91 sorry for the confusion.
Old Sep 23, 2010 | 07:44 PM
dwrestle's Avatar
dwrestle
Nobody knows about the compatibility of the steering columns? 87-91 doesn't look that much different than my 83, but 92-96 does look different.
Old Sep 25, 2010 | 02:39 AM
85_Blue's Avatar
85_Blue
I would check the starting push rod in the column for line up, and then I would check all the connections. You will be the resident expert when your done
Old Sep 26, 2010 | 12:32 AM
dwrestle's Avatar
dwrestle
Well I'm not even close to doing anything yet. I was just brainstorming(hoping someone would know for sure). It is a lot easier to find newer trucks with tilt wheel than 80-86 trucks. Also the 92-96 looks shorter(more room for my belly), but it may be that the dash is bigger to make it seem that way. Thanks for the input.
Old Sep 26, 2010 | 09:00 AM
ctubutis's Avatar
ctubutis
The only things I know:
I think it was around 1984 when Ford started including the key-in-ignition buzzer (and
associated wiring) feature into the trucks (formerly, this didn't exist) so there will be that to
deal with (which shouldn't be hard, I don't know if your 83 model has this or not).
In at least some - and possibly (probably) all - of the 80-86 trucks, a relay was added into
the horn circuit only when cruise control was installed at the factory, I don't know if or
when this may have changed in later years.
I don't believe tilt vs non-tilt would be much of an issue, nor can I imagine auto vs
manual transmissions (the PRND21 stuff as well as the lever) being a make-or-break
problem but getting replacement turn signal switches in the future will be more of a
challenge for the next owner unless they (you) remember to go looking for parts from the
year & application of the replacement column.
I don't remember the year they started the following two items but at some point they
began putting the windshield wiper & washer controls on the turn signal stalk, and air
bags came into the picture. Both of these would be need to be dealt with somehow as I
believe it was during this time when the steering wheels physically changed and became
incompatible with the columns from previous years.
AFAIK there are no major mechanical changes that would keep the later-model variants
from physically fitting & attaching to the steering system but I've never done it so, as
was said, you will become the resident expert. Let us know.
rwrogers
Jan 29, 2014 06:58 PM
StockMan
Oct 15, 2001 08:46 AM
greghoffmann
Jul 27, 2001 06:14 PM
jowilker
Jul 8, 2001 11:43 AM
ummduh
May 10, 2000 10:24 AM
