Loping on Startup
Old Dec 10, 2017 | 08:25 PM
IH Addict5088's Avatar
IH Addict5088
Loping on Startup
I've got a 2000 F250 7.3 that lopes on startup no matter the temperature. It also is somewhat sluggish getting up to speed. I was wondering if this could be a weak hpop causing this. Thanks for the help in advance.
IH Addict5088
I hooked a code reader to it. The truck has no codes.
Old Dec 10, 2017 | 11:53 PM
RigCity's Avatar
RigCity
Try tapping the throttle for a second literally my truck used to to this idk why but if I tapped the pedal for about 100rpm worth it would instantly go away
Old Dec 10, 2017 | 11:57 PM
RigCity's Avatar
RigCity
[QUOTE=RigCity;17648333]Try tapping the throttle for a second literally my truck used to to this idk why but if I tapped the pedal for about 100rpm worth it would instantly go away when below about 40 /QUOTE]
guess I need to read didn’t see at all temps you said
Have you done the fuel filter or checked the in tank screens?
Old Dec 11, 2017 | 12:00 AM
RigCity's Avatar
RigCity
[QUOTE=RigCity[/QUO
Old Dec 11, 2017 | 02:05 AM
IH Addict5088
I haven't done the filter for awhile. I changed it last time and it was still loping then. If I tap the pedal I have to keep pressing it for a few seconds and it stops.
Old Dec 11, 2017 | 04:20 AM
SpringerPop's Avatar
SpringerPop
Lope, schmope. Let it. It won't hurt anything.
If you have a real problem with it, change to a lighter DIESEL-RATED oil.
All caps for a reason.
Pop
haledamage
Sep 21, 2016 07:18 PM
HighOctane
6.4L Power Stroke Diesel
Jul 31, 2014 07:29 PM
LDD
Oct 14, 2013 03:53 PM
2006powerstroke90
20
Dec 20, 2011 10:31 AM
dmschmidt1200
Apr 28, 2011 04:09 AM
