throttle
Old Sep 21, 2016 | 05:41 AM
haledamage's Avatar
haledamage
throttle
my 02 f250 starts but has no throttle, i did replace the throttle body, still no luck, i did find a wire on the shiffter that had a bad spot , fixxed it still no throttle, code reader says it passes with no codes, i disconected both battarys and waited 15 to 20 min, reconected them, started the truck and let it idel for 20 min so what do i need to do now, please help. i just cant figure it out
Old Sep 21, 2016 | 07:27 AM
Rikster-7700's Avatar
Rikster-7700
What throttle body are you talking about? Is it a 7.3 F250 you have?
Or did you mean the throttle position sensor on the pedal?
Old Sep 21, 2016 | 11:04 AM
haledamage's Avatar
haledamage
I ment the tps on the pedal, i replaced the pedal assembly,
Old Sep 21, 2016 | 11:06 AM
haledamage's Avatar
haledamage
thanks for asking
Old Sep 21, 2016 | 01:20 PM
ExPACamper's Avatar
ExPACamper
No throttle sounds like out of fuel. Empty tank or problem with the fuel pickup lines. Have you done intank mods yet? (Hutch)
When is the last time you changed your fuel filter?
Old Sep 21, 2016 | 04:03 PM
z31freakify's Avatar
z31freakify
Check your wiring going into the APS and see if there's no cut wires.
Old Sep 21, 2016 | 04:08 PM
haledamage's Avatar
haledamage
APS
ok i will do that and get back to you
Old Sep 21, 2016 | 07:18 PM
carltonwebb's Avatar
carltonwebb
Blown fuse. I forget the number but seems like its one of the ones on the bottom row.
HighOctane
6.4L Power Stroke Diesel
Jul 31, 2014 07:29 PM
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
Pockets52
Mar 29, 2013 08:25 PM
joeyd61
Mar 5, 2013 02:18 PM
rondogw
Nov 21, 2010 12:16 PM
