Normal upgrades vs bigger injectors,turbo, etc...
on
I went with 160/80 Single Shots for the same reason- not as much oil and more fuel with cooler EGTs and better performance options.
I've been running W-I-D-E FIPW for some time and not getting what I know she wants to give
Hopefully this gets me closer. Just bigger turbo and HD trans left after this...hopefully both are down the road...quite a few dollars from now
Well I might as well make this my build thread. So thoughts between these (3) turbos.
Im leaning towards either of the t4 style because it comes with up pipes.
If I went that way how many of the "extra add ons" do I need to check
Option 1 https://www.iratediesel.com/irdie/pr...-complete-kit/
Does anybody have the specs between these two
Option 2 https://www.iratediesel.com/irdie/pr...dp-t4-s369sxe/
Option 3 Garrett GTP38R PowerMax Ball Bearing Turbo Ford 7.3L
Option 2 is what I was leaning towards.
and let the help commence
Another option to consider is the KC38R 366. Just finished my build. Very happy with it. EGT's are definitely good towing heavy or in street performance. And they are available within a few days.
Just another option to consider.
https://kcturbos.net/products/kc-7-3-stage2-turbo
on
on
I might even be convinced...very soon...
#29
#30
My problem (hesitation) is that I am still on stock injectors and don't know how the KC38R will fit in the system. I have been told the Garrett 38R does just fine with stock injectors, so I believe the KC38R would do the same or better, but it is an expensive gamble, at least in my neck of the woods.
Definitely something to think about though.
