Normal upgrades vs bigger injectors,turbo, etc...
Old 12-11-2017, 05:17 PM
Tugly's Avatar
Tugly
Tugly is offline
Originally Posted by ExPACamper
I thought you had 160/100 single shots? Or is that why you needed the Terminator 500 HPOP?
Crud... Singles. I went back and edited it.
The T500 was to fix an issue with ICP on the stockers... which wasn't the problem to begin with.
Old 12-11-2017, 07:09 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
I remember parts of that conversation, where you talked about the era of "you need big oil" but then tuners started working on things, including long FIPW and stuff.
I went with 160/80 Single Shots for the same reason- not as much oil and more fuel with cooler EGTs and better performance options.
I've been running W-I-D-E FIPW for some time and not getting what I know she wants to give
Hopefully this gets me closer. Just bigger turbo and HD trans left after this...hopefully both are down the road...quite a few dollars from now
Old 12-11-2017, 10:32 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
I always thought of the normal mods as supporting mods for going bigger, better, badder with injectors/turbos later.
Old 12-16-2017, 06:46 PM
POWER-RANCH's Avatar
POWER-RANCH
POWER-RANCH is offline
Well I might as well make this my build thread. So thoughts between these (3) turbos.
Im leaning towards either of the t4 style because it comes with up pipes.
If I went that way how many of the "extra add ons" do I need to check
Option 1 https://www.iratediesel.com/irdie/pr...-complete-kit/
Does anybody have the specs between these two
Option 2 https://www.iratediesel.com/irdie/pr...dp-t4-s369sxe/
Option 3 Garrett GTP38R PowerMax Ball Bearing Turbo Ford 7.3L
Option 2 is what I was leaning towards.
and let the help commence
Old 12-16-2017, 06:48 PM
POWER-RANCH
Also christmas came early for the ole truck. The Isspro gauges and Frx kit came in today.
Now I wont get so many shameful looks for not monitoring EGT's.
Old 12-16-2017, 07:35 PM
akcooper9's Avatar
akcooper9
akcooper9 is offline
Power Ranch, send me a PM and lets talk. I will walk you through my trials and tribulations over the past 6 months. You are very close to success with option 1
Old 12-16-2017, 10:17 PM
BLUEMAX65's Avatar
BLUEMAX65
BLUEMAX65 is offline
Another option to consider is the KC38R 366. Just finished my build. Very happy with it. EGT's are definitely good towing heavy or in street performance. And they are available within a few days.
Just another option to consider.
https://kcturbos.net/products/kc-7-3-stage2-turbo
Old 12-17-2017, 07:29 AM
ExPACamper's Avatar
ExPACamper
Website still says sold out?
Old 12-17-2017, 08:44 AM
BLUEMAX65's Avatar
BLUEMAX65
When I ordered mine I told them it shows out of stock. Charlie mentioned they need to update that. But my order showed up in a couple of days.
But I am in AZ where they are located.
Old 12-17-2017, 09:05 AM
ExPACamper's Avatar
ExPACamper
Are you saying they have them and are shipping them? A number of folks have been holding up on ordering because they are unavailable. When did you order yours?
I might even be convinced...very soon...
Old 12-17-2017, 09:35 AM
Sous's Avatar
Sous
Sous is offline
Received 4,572 Likes on 2,900 Posts
Old 12-17-2017, 10:15 AM
BLUEMAX65's Avatar
BLUEMAX65
I ordered mine two weeks ago. And two days later after I placed the order it showed up.
  #28
Old 12-17-2017, 10:33 AM
Sous's Avatar
Sous
Sous is offline
Man, now I have to seriously consider if Santa wants to do a turbo swap on my truck...
  #29
Old 12-17-2017, 10:41 AM
BLUEMAX65's Avatar
BLUEMAX65
You won't be sorry. My buddy has the old 38r and it's LOUD. Even with an 6637 style filter it's so much quieter and spools up so quick.
  #30
Old 12-17-2017, 10:59 AM
Sous's Avatar
Sous
Sous is offline
My problem (hesitation) is that I am still on stock injectors and don't know how the KC38R will fit in the system. I have been told the Garrett 38R does just fine with stock injectors, so I believe the KC38R would do the same or better, but it is an expensive gamble, at least in my neck of the woods.
Definitely something to think about though.
Quick Reply: Normal upgrades vs bigger injectors,turbo, etc...
