Normal upgrades vs bigger injectors,turbo, etc...
#31
My problem (hesitation) is that I am still on stock injectors and don't know how the KC38R will fit in the system. I have been told the Garrett 38R does just fine with stock injectors, so I believe the KC38R would do the same or better, but it is an expensive gamble, at least in my neck of the woods.
Definitely something to think about though.
When I was researching the T4 or drop in on another site their were a few people running a 366 T4 with stock injectors with no problems.
#32
on
#33
#34
I got a good start on putting in the gauges this afternoon. BUT, where are you guys putting the transmission temp sensor? I don't really like the looks of the "clip over line" setup.
I saw on a youtube video earlier that a guy put it in the spot of a plug on the drivers side of the transmission. (automatic).
Pics would help.
Thanks!
Pics would help.
Thanks!
#35
Pics would help.
Thanks!
Pics would help.
Thanks!
The test port on the drivers side of the transmission. (Automatic)
#36
Pics would help.
Thanks!
Pics would help.
Thanks!
I bought a steel pan " Derale performance " It has a bung for the temp sensor. It costed me 100.00 and also added seven extra quarts.
#37
#38
#39
#40
Yes the sensor threads right in. That is the location recommended by Mark, the former Ford auto tranny engineer.
#41
I found Mark's recommendation on the sensor location.
Post #4 of this thread. https://www.ford-trucks.com/forums/1...ure-gauge.html
#42
Also how many of yall are running dual EGT probes but only running on one gauge switching back and forth between them?
Good idea? any better ideas?
I had already ordered the kit when I read on here it is better to have both sides monitored when running bigger sticks and turbo
#43
Same here... but something is intermittently wrong in my engine. I have something on the driver's side that is not quite right, and the left gauge dips when it happens. I can feel it, hear it, and see it on the gauge... but it's too intermittent right now to nail it with troubleshooting. All I can say is if it weren't for the dual EGTs, I couldn't even narrow it down to which side the problem is on.
#44
