I just noticed that my inverter shuts off when I open my driver door even when the truck is running. When I shut the door it comes back on. It does not do this with any other door. Has this happened to anyone else? If so what could it be?
I just noticed that my inverted shuts off when I open my driver door even when the truck is running. It does not do this with any other door. When I shut the door it comes back on. Has this happened to anyone else? If so what could it be?
Reason: Delete double post
By any chance do you have done any Forscan mods? Mine had a issue when I did the secure idle, inverter would work only when I had the brake pressed. Went back to factory no mod and all works good now
The inverter works from the Body Control Module (BCM) I went line by line on Forscan comparing with the original as build, but check the lines on the BCM maybe accidentally may have change a line or number on it, I don’t know what line it is but mine was the secure idle, the mod that it would not let you move from park if no key is detected
It’s weid because I haven’t heard anyone with this issue till I mention it on the Forscan thread, now people left and right having the issue, you are welcome that is why we have this forum so we can fix things like this
