Pass. door won't open??
Old Jan 26, 2010 | 03:23 PM
alconk's Avatar
alconk
I just installed new door strikers and adjusted the doors but now on my last shut for the pass. door it won't open?? From either side like it's locked. So I assume something came loose in the door maybe?? Bothe handles operate just won't open the door??
Old Jan 26, 2010 | 03:58 PM
robertbenita's Avatar
robertbenita
I had my door panels off not too long ago and I think you can access the mechanism to open the door without using either door handle once the panel is removed. Not much help, but the bright side is that it wasn't the driver's side forcing you to slide over until it is repaired. Good luck and hope it's not too bad!
Old Jan 26, 2010 | 05:46 PM
alconk's Avatar
alconk
Appreciate it, will check out when a little warmer. I hate winter!!
