V10 E4OD on a 460 : possible ?
Old Nov 26, 2017 | 09:55 AM
BigDan1's Avatar
BigDan1
I found some similar threads but nobody ever answered directly ....
I have a 1996 460 ( 7,5L ) in my E350 , the tranny starts to act on me .....
Id like to know if a more recent 6 speed E4OD would fit on my 460
Is the bell housing bolt pattern the same ?
( I know I would have to get a special ECM harness converter )
Thanks
Old Nov 26, 2017 | 05:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What is a 6 speed E4OD? Every E4OD that I'm aware of is a four speed.
Anything is possible with enough time and money. The bellhousing bolt pattern is not even close. You will need a custom adapter plate, and that's not going to be cheap.
Old Nov 26, 2017 | 07:16 PM
BigDan1's Avatar
BigDan1
Thanks Mark,
Ill get my 4 speed rebuilt then .....I would have like to get more speed ...
Maybe the designation letters are not right but the newer OD tranny has 6 speed....
Dan
Old Nov 26, 2017 | 09:24 PM
Mark Kovalsky
The newer six speed automatic is called the 6R140. And it won't bolt to a 460, either.
Old Nov 27, 2017 | 06:25 AM
BigDan1's Avatar
BigDan1
Thanks Mark,
Ill either rebuild my E4OD with HD components , and rebuild my 460 to 400 hp at same time
or then , if feasible ( $$$) , transplant a 6.2L + 6R140 in the Class C ....
I like the way these 6R140 work ,,,
what do you think of this project ....great or a no-no ?
I`m not rich , just a good handymecanic ;-)
the harness should be the biggest problem ,,,
Dan ,
Old Nov 27, 2017 | 07:27 AM
Mark Kovalsky
It can be done. I expect it will take A LOT of work, and A LOT of cash. It certainly isn't a bolt in project.
Old Nov 27, 2017 | 07:34 AM
BigDan1's Avatar
BigDan1
I guess ill abandon .....
the rebuilt 460 will give plenty of power ...
the E4OD has a major step between 3rd & 4th gear
I have 4:10 ratio....when I climb i take the OD out , it gains lots of RPM
I would have like the 6 speed for better transition between gears .....
but $$$$ ,;-(
Old Nov 27, 2017 | 01:22 PM
85e150's Avatar
85e150
Gear vendor behind the e4od. Serving suggestion.
Old Nov 29, 2017 | 12:04 PM
cbakker's Avatar
cbakker
+1 on the gear vendor overdrive. This will solve your problem for a lot less money. You will be very unlikely to achieve 400 hp on a speed density efi 460. Stick with what you have, and cut out the air horns, open up the exhaust ports a little, and go through the basics. Plugs, wires, fuel filter, and fresh fluids. A 400hp motor home will only create more problems. Your stock engine should produce about 240. With a little head work, and my other recommendations, you might see 280.
Caleb Cook
Mar 19, 2017 05:12 PM
chrisek
Jan 7, 2016 08:20 PM
twisted84toyota
May 19, 2015 09:27 PM
THE KING
Jan 3, 2008 11:17 AM
oregon250
Oct 3, 2002 10:08 PM
