Simple yes or no, Did they make a F250 4x4 in 78-79 with a coil spring front?
My nephew bought one, I suspect is a put together truck. I'm not there to look at the serial number
If could be a 1/2 ton and someone put 8 lug spindles on the front axle and swapped in a rear 8 lug axle and then rebadged it.
And odd duck is a F150 4wd with front leafs..only in a SC.
What I think too. But I just learned about the leaf spring F150s even though I've been immersed in Ford pickups since I bought my first new one in 1974. Which ironically enough was an F250 4x4 that escaped the factory with F100 fender badges.
