Fuel Pump Ford 400 -77
Can you please help me out. Need to order a Mechanical Fuel Pump from Summit. Do you know which one would fit my 400 -77 (4x4, aut, no AC)
Thanks!
https://www.summitracing.com/int/parts/crt-m6882
https://www.summitracing.com/int/parts/crt-m6978
Thanks!
Before you order from summit rock auto has the same carter pump for $13 if you go with the 6882.
https://www.rockauto.com/en/catalog/...fuel+pump,6256
I know I've used the 6978 on my 79 F250 4wd.
The only difference I can see is the inlet and outlet orientation, one has the inlet on the left and the other is on the right and they face different directions. All the specs on those two links are the same. They'll both physically fit your 400. If it's any help, I looked up mechanical fuel pumps on summit for my 78 Bronco with a 351M (same block as the 400) and it pulls up the m6978. I replaced mine on my Bronco not too long ago with one from an auto parts store and it looks the same as that one.
This one is from a different supplier, but has the same part number for the pump, 6978. It says it'll fit 4x4 '77's. I would assume the carter would work or any other 6978, but then again! I would just keep second guessing yourself until you don't buy one at all, it'll save you money.
https://www.summitracing.com/parts/a...977/make/ford/
1977 F100/350 2WD & 1977 F150/250 4WD 351M/400 use the same fuel pump. It was also used on cars:
D7SZ-9350-C (replaced D6AZ-9350-B; D7SZ-9350-B & D7TZ-9350-A) .. 351M/400 Fuel Pump / Obsolete
1977 F100 2WD / 1977 F150/250 2WD/4WD & F350 / 1978 F150/250 2WD & F350.
1976 LTD/Grand Marquis/Torino / 1977/78 LTD/Grand Marquis/LTD II(not an LTD!)/Thunderbird/Cougar/Ranchero / 1979 Thunderbird/Cougar.
Note: 1978/79 F150/250 4WD/Bronco & 1979 F350 4WD 351M/400 use a different fuel pump: D8TZ-9350-B
Hi!
I just want to confirm your information about my Fuel Pump. I took a Picture of the Pump yesterday and it look exactly like the one you suggested (M6882).
The inlet (hose barb) and the outlet (threads) are at the same places. it's probably 41 years old and I can read "MADE IN U.S.A" on the Pump.
Almost a shame to replace it for an asian Pump! Thanks a lot!!!
black & blue 78/9
06-13-2019 12:06 PM
kc5hwb
07-30-2006 09:52 PM
