fuel tank selector problems, need advice
Old Nov 23, 2017 | 09:04 AM
waltharper's Avatar
waltharper
My f150 has two fuel tanks. the switch inside the cab will make only select the rear tank. the front tank is full but when selected i run out of gas.
Another problem is that the fuel Gage shows when selected both tanks are above the full mark by a long ways. Actually more then it should, excessively full, needle past the stops, if you get my point.
Now would this be the selector switch fault or something else?
Where would this selector switch/valve be located at?
any suggestion or ideas would be helpfull.
thanks
Old Nov 23, 2017 | 09:17 AM
Conanski's Avatar
Conanski
What year is your truck? There is no selector valve on gas trucks built after 1989.
Old Nov 23, 2017 | 09:26 AM
waltharper's Avatar
waltharper
1988 f150
has two tanks and the switch is below the instrument cluster, left hand side of the steering column.
Old Nov 23, 2017 | 09:28 AM
waltharper's Avatar
waltharper
not sure if you can see the switch.
Old Nov 23, 2017 | 11:04 AM
josiewales's Avatar
josiewales
at
Very common problem on your mode/year truck. Your truck has a fuel valve(reservoir) on the frame rail that accomplishes the switching from one tank to the other. The switch on the dash supplies power to either the front or the rear tank pump. The pressure from the tank because the pump is running causes the valve to switch positions, supplying pressure outgoing to the engine and switching the return fuel to go to the tank supplying the fuel. Your valve isn't switching to the front tank, thus no fuel is leaving the valve going to the engine from the front tank.
Two solutions: Rebuild the valve or replace the valve. (or just drive on the rear tank) I found the valve on Amazon, original Ford part, for $100 to $200. But there are folks here rebuilt their valve.
Old Nov 23, 2017 | 11:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by waltharper
1988 F150
Has two tanks and the switch is below the instrument cluster, left hand side of the steering column.
E7TZ-9A050-A .. Fuel Tank Selector Switch-6 terminals, mounted on instrument panel / Marked: E7TB-9A050-AA or AC / Available from Ford.
1987/89 F150 & F250/350 gas & diesel / 1990/91 F250/350 & F(Super Duty) diesel.
MSRP: $60.47 / autonationfordwhitebearlake.com online price: $36.59.
However, the switch may not be the problem, more than likely, it's the valve. Every type of these valves used in the 1980's were a notorious POS!
And btw: The 'pig boats' you served on...wouldn't those have been SSN's?
Old Nov 23, 2017 | 11:32 AM
subford's Avatar
subford
Could be a bad pump in the front tank also or a bad selector switch at the dash area.
Do you hear the front tank boost pump running for one second each time the key is turned on when selected.
Attachment 280309
Old Nov 23, 2017 | 06:21 PM
vjsimone's Avatar
vjsimone
FYI - 88' EVTM
tmrider
Apr 13, 2019 10:13 PM
powerstroke79
Oct 8, 2013 04:50 PM
va150
Aug 7, 2010 12:02 AM
joe69
Jan 20, 2005 10:19 AM
DHendricks
Mar 1, 2002 10:51 PM
