Fuel Tank Switch
Old Aug 6, 2010 | 08:13 AM
va150's Avatar
va150
Fuel Tank Switch
I have an 6.9 87 F-350 with dual tanks. The front tank is working but will not switch to the rear tank. When switched to rear it keeps running from the front tank. Other than the switch itself is there anything else it could be?
Old Aug 6, 2010 | 08:52 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The FSV ... (Fuel Selector Valve)
When you flip the switch you should hear the FSV change tanks, the FSV is located in the frame just behind the cab.
-Enjoy
fh : )_~
Old Aug 6, 2010 | 11:58 AM
va150's Avatar
va150
Got it, thanks!!
Old Aug 6, 2010 | 08:16 PM
eraser5's Avatar
eraser5
Slight hijack, but still somewhat relevant.
I have been told I should replace the O-rings in Fuel Selector Valve. 6 in all I believe. But I cannot find the O-rings at any of the parts stores. Any ideas for a source?
Old Aug 6, 2010 | 09:14 PM
02X72's Avatar
02X72
What does it sound like when it switches, or working properly? Ive heard it makes a buzzing sounds, but mine just kind of clicks? Could you clarify a little on the sound?
Old Aug 6, 2010 | 09:47 PM
Festus Hagen
Methanoholic
A heavy click is how I would describe it ...
Buzzing would indicate a failure.
Someone that knows the internals needs to jump in ... I have never been inside one.
-Enjoy
fh : )_~
Old Aug 7, 2010 | 12:02 AM
johnboggs21's Avatar
johnboggs21
ive heard it described as kind of a ziiiip noise.
merbno
Oct 14, 2014 05:36 PM
kermmydog
Jul 16, 2013 10:38 PM
ZHMMY
Feb 3, 2013 10:22 AM
van1989
Apr 18, 2009 10:29 PM
disco
Feb 11, 2004 07:00 AM
