76 ford high boy 360 engine temp problem
When I bought my 66 with the 352 it would get hot like that in a hurry, ended up someone put the drivers side headgasket on wrong and blocked the cooling passage off at the rear of the block
Pressure caps, I'm not sure what was stock, but that's what I usually stay with - figuring that lower might be easier on a questionable radiator and heater core.
(on my own junk, that is)A good flush on the radiator with cleaner seems to help on old Fords as much as anything - I don't know if the tubes are narrower than others, these just didn't have quite enough radiator, or what it is, but I've had several that had heating problems that ended up being a restricted radiator. You can't get the good ol' Permatex radiator flush anymore (that I've found), but I've used the Prestone stuff before and it seems to knock the slime out pretty well. Then "I" tend to use regular Lime-A-Way, Barkeeper's Friend, or any of those regular household calcium/hard water products and give it a good cycle, then a REALLY good flush. Some will say it's too harsh, bad for copper/aluminum/etc., and it probably is, but I figure if it will eat through the copper that fast, it must have been thin enough it was gonna start leaking pretty quick anyhow.
There's also some commercial rust/scale remover products that work well, I had a friend that worked at a hottub/pool place for a while and they had some stuff that worked like a champ.I've heard the argument that "new" gas with ethanol makes these heat more, too - and maybe it does, don't really know. If that's the case, they just flat don't have enough radiator - I've swapped in an E-Bay Champion on one with a slightly built 400 (deer antler - don't ask
) and it ran significantly cooler with the aftermarket aluminum. Food for thought.....On Edit - I didn't see Tedster's post above - he's absolutely right, running them "cold" is a bad thing, I believe 180-185 was factory? I've run them without a thermostat for diagnostic reasons, but not something you want to do long-term -
If nothing comes out, poke the hole with a screwdriver and stand clear. Built up scale and sediment settles to the bottom galleys and there will be a torrent of muck coming out!
Flush til it runs clear. Then back flush it too by positioning the hose right up against the block hole. Then flush from the top again.
