My 1978 f series pickup needs a new a/c dash panel. It has 2 vents on the right and the control ***** on the left. I can only find the center vents and not the a/c control panel.
This is what it is supposed to look like. Mine is all busted up. Anyone know where I can find one?
A/C panel that contains two registers and two switches, located in the dash to the left of the glove box:
This is dealer installed Economy A/C, it's not factory installed Integral A/C or Deluxe dealer installed A/C, because both of these are combined with the heater.
Economy A/C is not.
Economy A/C will be found in 1973/79 F100/350 & 1978/79 Bronco, but the later panel (pictured above) has the switches on the left side, while the earlier panel has the switches mounted horizontally below the registers.
