Trans code M
Old Nov 20, 2017 | 09:17 AM
Diesel_Brad's Avatar
Diesel_Brad
Trans code M
Can anyone tell me what trans code M is for?
it is in a 96 F150
is it a zf5?, m5od, or 4 speed?
Old Nov 20, 2017 | 10:35 AM
Freightrain's Avatar
Freightrain
U – Automatic 4R70W (F-150, F-250)
E – Automatic E4OD (F-150, F-250)
M – 5 speed manuaoverdrive (F-150, F-250, Ranger)
D – Automatic 5 speed (Ranger)
T – Automatic 4 speed (Ranger)
Says 5 spd OD. I'd guess a M5od since it's a F150.
Old Nov 20, 2017 | 02:48 PM
Conanski's Avatar
Conanski
No 4 sp or ZF in a 1/2 ton of that vintage.
Old Nov 20, 2017 | 04:16 PM
Diesel_Brad
Ok, just clarifying.
Someone INSISTS that the truck is all original and that it is a 4 speed.
Just wanted to fact check before I called them FOS
M is Mazda M5OD
C is a ZF5
Old Nov 20, 2017 | 04:50 PM
'89F2urd's Avatar
'89F2urd
Have you seen the shifter or Trans itself? He very well may believe he has the Ole "4 speed with overdrive", when he just isn't knowledgeable/smart enough to know that it's simply a 5 speed and a 4 speed with overdrive doesn't exist.
Old Nov 20, 2017 | 05:27 PM
Diesel_Brad
No I have not. But he is claiming..... it is a granny 4 speed. And when questioned about it.... "it came stock matching numbers had a buddy who had another one like that and my dad" AKA a kid who doesnt know what he is talking about
Old Nov 20, 2017 | 05:42 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
The mazda trans doesn't have no granny gear,that's for sure.So he's just totally clueless what a granny gear is,or doesn't know someone swapped in an old 4 speed trans.Pretty harmless.I'd just let the kid think what we wants lol.
Old Nov 20, 2017 | 06:09 PM
'89F2urd's Avatar
'89F2urd
Ahhh....onea those guys lol
Old Nov 21, 2017 | 09:17 AM
Freightrain
Depending on what gears are in the back of the truck, the first gear in a M5 is pretty steep. Not quite granny gear steep, but I know my '89 with 3.55's in the back was pretty short in 1st gear. Barely had to let the clutch go and you shifted it. Second gear was not quite enough and it would lug if you tried using it.
The "unknowing" kid would likely think it was a granny gear.
Old Nov 21, 2017 | 04:50 PM
Diesel_Brad
I have 4.88s and a the m50d. Still wish it was steeper
Old Nov 22, 2017 | 09:28 AM
Freightrain
What are you hauling with that truck? 3.90 x 4.88 = 19.0/1 first gear.
(The T18 is 5.1 in first gear)
I never had to pull anything heavy, since I have a Mack truck in the garage to do my heavy work.
Old Nov 22, 2017 | 05:45 PM
Diesel_Brad
Not a dam thing other than A S S. It is in my bronco with 35s
crrroger
Jul 13, 2011 12:13 PM
Roger T. Pipe
Oct 22, 2009 01:23 AM
Truckin4life
Mar 12, 2008 08:09 PM
1988F1504x2
Dec 17, 2006 11:57 PM
hillbillyk
Jun 24, 2003 11:50 PM
