ZF 5 speed id
Old Jun 24, 2003 | 03:02 PM
hillbillyk's Avatar
hillbillyk
ZF 5 speed id
when did ford start putting the ZF 5 speed into 3/4 ton 4x4's, I found a 87 or 88, something like that with a 5 speed, trans code is Z, trying to find out what this is, I don't want the wimpy mazda tranney, it is behind a small block, how would I tell by looking at it also, thanks,
Bill
Old Jun 24, 2003 | 03:16 PM
andym's Avatar
andym
ZF 5 speed id
If it's a 3/4 ton with a 5 speed, it's a ZF. To my knowledge, Ford never put the Mazda in anything bigger than a half ton. Also, I believe the trans code you're looking at is a 5, not a Z. The Mazda has a code of M.
Old Jun 24, 2003 | 06:32 PM
gamehunter's Avatar
gamehunter
ZF 5 speed id
The mazda's trans code is M, but you still need to watch out because ford did in fact, put the the mazda into many 3/4 ton trucks. But I believe that was only with the 5.0 engine and not the 4.9 or 5.8 which were only offered with the ZF in 3/4 ton or 1 ton frames.
Old Jun 24, 2003 | 09:57 PM
eckart's Avatar
eckart
ZF 5 speed id
Mazda 5 speeds can be found in the light duty 3/4 tons. They had 302s and only a semi floating rear end. ZF tranys have the angled cross hatch ribbing on the sides of their case.
Old Jun 24, 2003 | 11:50 PM
steve83's Avatar
steve83
ZF 5 speed id
Manual transmissions
