5 Speed Trans ID?
Old Oct 18, 2009 | 11:34 AM
Roger T. Pipe's Avatar
Roger T. Pipe
5 Speed Trans ID?
Anyone know the diff between Mazda/Toyo & the 2 other trannys for a 300 6 5 speed 150? i Have a few junkyard units to choose from, but there seems to be a few. The one I'm looking for fits a 1996 150 6 cyl 2WD 5 speed truck. Thanks!
Rog
Old Oct 18, 2009 | 02:50 PM
Blue Rebel's Avatar
Blue Rebel
The only 5 speed available for the F150 is the mazda M5R2 (sometimes called the M5OD) The other trans available in the F150s were either 3 speeds or 4 speeds.
Old Oct 18, 2009 | 02:55 PM
89250jk's Avatar
89250jk
do you by any chance know where i can get a transmission for an 89 f250 4x4 with a 302? call if you know 937 902 2279 my name is josh
Old Oct 18, 2009 | 07:49 PM
89ford73's Avatar
89ford73
i have seen a top loader transmission in a 4x4 f-150 that is a 5 speed what is that one called? i know the other trans that fits a 302-351 is the zf5 which is a really good tranny
Old Oct 18, 2009 | 07:51 PM
89ford73's Avatar
89ford73
if it has places to put a pto, it is a zf5, if it is not a top loader, then its the mazda, the top loader i think they call it a t-3 or t-something that sounds like a borg warner to me. but im not sure
Old Oct 18, 2009 | 07:58 PM
Blue Rebel's Avatar
Blue Rebel
The top loaders available in the F150s were the T-18 and the T-19, both 4 speeds. The Tremtec T-5 was a mustang trans that was never put in an F150 from the factory.
Old Oct 18, 2009 | 08:04 PM
89ford73's Avatar
89ford73
i saw a top loader 5 speed with a transfer case behind it came from a 1990 f-150. what tranny was that? all aluminum case
Old Oct 18, 2009 | 08:19 PM
Blue Rebel's Avatar
Blue Rebel
in 1990 it should have been the mazda M5R2. Im not saying you didnt find a truck with a T5 in it, it would bolt right up to a 302. Just didnt come that way from the factory. Was the bellhousing integral with the case, or were they 2 seperate pieces?
Old Oct 22, 2009 | 12:39 AM
RJG1987's Avatar
RJG1987
I've been looking for some threads of the t-5 somewhere on here, my 5 speed died tonight 171k original. A t-5 in an f series would be cool to see or do, Wonder how it would go?
Old Oct 22, 2009 | 12:52 AM
85e150's Avatar
85e150
Trans pics here:
Domestic Truck Tranny Guide
T5? A couple Mustang models had a 3.35 first. That and a steel bearing retainer might work. You'll need an adaptor due to input shaft issues.
These guys sell the stuff to do it with:
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Old Oct 22, 2009 | 01:23 AM
Alvin in AZ's Avatar
Alvin in AZ
Borg Warner T18
...Used in Ford trucks 1956-73,...
Funny how you'll find a mistake like that one place then later another and so on.
Don't anybody do their own research? Seems everybody just cuts and pastes. :/
The two lower tags came off of T18's that were in '75 Ford pickups, the tag sez
it's '74 part number. LOL :)
http://www.panix.com/~alvinj/file12/Ftags.jpg
Alvin in AZ
54TexasF100
2015 - 2020 F150
16
Jun 23, 2016 10:17 PM
nightowl263
19
Dec 3, 2015 10:24 PM
2xford
Sep 22, 2011 09:40 PM
KyleG
17
Mar 25, 2009 07:21 PM
Dieselguy89
1997 - 2003 F150
May 3, 2008 08:28 AM
