Ambient Air Temp Sensor
Old Nov 17, 2017 | 01:23 PM
HDDave2014's Avatar
HDDave2014
2014 F250 6.7 Powerstroke. Location of sensor
Old Nov 17, 2017 | 01:47 PM
nuctrooper's Avatar
nuctrooper
Passenger side mirror
Old Nov 17, 2017 | 02:02 PM
HDDave2014's Avatar
HDDave2014
Will this cause temp read out on dash to go nuts??
Old Nov 17, 2017 | 02:11 PM
nuctrooper's Avatar
nuctrooper
You gotta give us a little more to go on. And - welcome to the forums!
Let us know the symptoms, indications, anything obviously wrong, etc. Did you smash the mirror off on a telephone pole - yes, your ambient temp may be jacked up. Is it just going crazy with no other indications? Could be water in a wiring connector or a bad temp sensor.
Edit - and, also I suggest the 99-16 Superduty forum instead of the 6.7 motor forum for a little better visibility if we can't fix it here
Old Nov 17, 2017 | 02:16 PM
HDDave2014's Avatar
HDDave2014
I'm getting a p0073 code with CEL. Climate control seems to work OK in manual mode , but not in Auto. Temp readout on screen sometimes reads -30 and moves up & down or just shows ----.
Old Nov 17, 2017 | 06:33 PM
m-chan68's Avatar
m-chan68
To add to the above that I've seen my share of, I've also seen more than a few with what I call the Ambient temperature sensor delete option, a k a someone else installed a passenger side mirror intended for '08 to '10 Super Duty trucks without the sensor. I'll say it sure has increased our passenger side mirror sales when these come in.
Old Nov 17, 2017 | 06:49 PM
nuctrooper's Avatar
nuctrooper
Aha. Yep, look for wiring breaks or chafing on the cables near the passenger door hinge and into the passenger mirror. Sounds like a flashlight and some wiggling of cables is in your future. Youtube is a good reference for how to remove the mirror and door trim if it comes to that. Good luck!
8e3k0
6.7L Power Stroke Diesel
Feb 16, 2016 12:51 PM
ssg510
Aug 5, 2012 12:56 AM
RobInAB
2004 - 2008 F150
Sep 6, 2006 07:59 AM
chazglenn3
Nov 18, 2005 07:45 PM
