5.9 Cummins length?Help
Old Nov 20, 2017 | 09:53 PM
Coleton_henry's Avatar
Coleton_henry
Originally Posted by 00t444e
The 7.3 idi will be a real turd when pulling a 48ft trailer, even with a turbo.
Yea, lots of difference between a 7.3 idi and a 7.3 powerstroke
Old Nov 20, 2017 | 09:55 PM
uniwagon's Avatar
uniwagon
Not really my truck has 2 transmissions,a BW T18 main, and a Spicer 6041 auxiliary. The aux has LL=2.14:1,L=1.14:1,D=1:1,OD=0.86:1.I can split each gear in main box 3 times and have a total of 16 gears and 4 gears in reverse...........and I can tow at highway speed loaded in OD.
Chris
Old Nov 20, 2017 | 10:03 PM
00t444e's Avatar
00t444e
Have you considered a 4bt Cummins? With a few mods they can make 300hp and 600 ft lb of torque and still be reliable. It takes some a lot more work to get a 7.3 idi to that level.
Coleton_henry
Chris
yea thats all real nice if he had that, but he doesn't
Old Nov 20, 2017 | 10:04 PM
Coleton_henry
Not to mention dam good gas mileage !!
Old Nov 20, 2017 | 10:11 PM
uniwagon's Avatar
uniwagon
I don't quite get the angle of that statement.
C.
Old Nov 20, 2017 | 10:23 PM
uniwagon's Avatar
uniwagon
Hello, I can't put in a 4 cylinder cummins because none where ever installed in ford trucks.That is an industrial engine not automotive.I am moving to west coast somewhere,and the 460 will never pass the smog deal ect............. so I can convert to a factory diesel that is exempt up to 1997 and register as a diesel powered truck.But it must be a engine = or newer in year to the truck and of 3/4 or one ton rated truck that was installed from the factory to be legal.5.9 cummins is to long and I am not dealing with a powerstroke conversion at this point in my life and I have to modify the oil pans on any engine to clear the steering.
C.
Old Nov 20, 2017 | 10:28 PM
uniwagon's Avatar
uniwagon
C.
Now i get it.Yes those are indeed the shifters in my truck,and here's the truck.
Old Nov 20, 2017 | 10:51 PM
Coleton_henry
My bad I thought that was someone else username when I read that.
Old Nov 20, 2017 | 11:39 PM
77highboy77's Avatar
77highboy77
C.
There were plenty of 4BT Cummins engines in automotive applications, mostly delivery trucks. They also came with a variety of bellhousing adapters, so you could get lucky and find one with a Ford bellhousing. This should get you past the automotive engine issue, though I can't say for sure since I don't have experience with CA emissions.
Old Nov 21, 2017 | 10:17 AM
uniwagon's Avatar
uniwagon
Yes, I get all of that but no 4bt in a 3/4 ton or one ton factory.The diesel must come from a truck of the same weight rating or one class below =F250 or F350 chassis.And if later I would like a better engine don't powerstrokes bolt in where an idi was.
Chris
Old Nov 21, 2017 | 10:29 AM
JakeHan's Avatar
JakeHan
Yes, Powerstrokes have the same bellhousing pattern as an IDI, believe it's an old IHC truck pattern, same as a 404/446 gas truck motor? (not sure if it's the same as a 304/345/392 or not, don't know that side of IHC stuff very well). IIRC, they used 435's behind the 6.9/7.3's, not T19's, can you bolt a T19 to a 435 bellhousing, or will you have to change to a 435?
Old Nov 21, 2017 | 11:07 AM
  #28
uniwagon's Avatar
uniwagon
Hello,the front trans in my truck is a T18 and that is staying.The low 1st is nice for maneuvering with a trailer at the drag strip.I all ready have the aluminum 6.9 bellhousing for the 4spd. I can also compound 1st gear as low as 13.5:1 with the spicer.
Chris
Old Nov 21, 2017 | 11:16 AM
  #29
JakeHan's Avatar
JakeHan
I think I was wrong anyway, they used T19's on the 6.9's and not NP435's. What was the difference between the 18's and 19's?
Edit - Synchro first gear - I knew as soon as I asked it'd come back to me.
mharring
Nov 24, 2010 10:45 PM
mountaineer27
Engine Swaps
30
Aug 5, 2009 12:12 PM
Mikestrucks
General Diesel Discussion
Sep 20, 2007 12:00 AM
mike manglos
Nov 23, 2006 10:22 AM
bil
Oct 15, 2006 11:07 AM
