Sponsored by: Real Truck
transfer case swap
Old Aug 6, 2018 | 12:24 PM
Desert Don's Avatar
Desert Don
Originally Posted by Fefanatic
My answer was not for your question. You broke into this thread with your own question when you should have started a thread in a different forum. I was answering the OP original question. Reading is fundamental. Try it sometime.
reps intended.......but rep gun empty.
Old Apr 21, 2021 | 07:31 PM
upgrade42's Avatar
upgrade42
transfer swap
ok so i believe what u may have found on ur swap is 1 being. the obvious ones eletric & ones manual .but they should boltup .also u can always remove the eletric motor from ur transfer case and with a drill & tap to mount the z-linkage and shifter & u can make it a manual transfer case.
Old Apr 22, 2021 | 03:06 PM
leadmic's Avatar
leadmic
Most all Ford transfercases of all years will bolt to any 4X4 Ford transmission. All of them that I have had experience with use a six bolt round flange and most use a use a 31 spline out put shaft I believe. Now if it will fit between the frame rails and the wiring differences between a manual and an electric I cant help you.
dumptruck denny
Nov 20, 2017 04:50 PM
parrothead85
Jan 22, 2013 08:27 PM
killbill
Jul 9, 2009 10:52 PM
jmbfarmall
Mar 28, 2009 12:47 PM
lenrsmith
Mar 2, 2004 09:41 PM
