Testing Starter Solinoyd (sp)
Old Nov 15, 2017 | 10:11 AM
Supercab's Avatar
Supercab
Truck started just fine at home last night, drove about 10 miles, tried to re-start now just clicks......
Is it possible to test the solinoyd with the starter still on the truck?
Thanks Guys!
Old Nov 15, 2017 | 11:05 AM
Chevota_72's Avatar
Chevota_72
Yes. I think you have two solenoids for the start circuit in your year. One on the fender well and then the one on the starter. Both can be tested while on the truck with a multimeter.
Old Nov 15, 2017 | 11:11 AM
Chevota_72's Avatar
Chevota_72
If you have the one on the fender well it is easiest to start there with troubleshooting. You should have constant 12v on one large lead then when you try to crank then you should have 12v on the other large lead. Start there and let us know what you get.
Old Nov 15, 2017 | 06:28 PM
Supercab's Avatar
Supercab
Thanks! Its a friend's truck and he is a ways away. just trying to help...
Old Nov 16, 2017 | 08:26 PM
timmyboy76's Avatar
timmyboy76
Throwing it out there because I'm buzzed, but, when the gpr-led mod was the next best thing to sliced bread, when I did that mod, I also installed an led onto the starter relay, for this very reason
Old Nov 17, 2017 | 12:48 AM
Supercab's Avatar
Supercab
This isn't my truck guys, its an '01-will IT have 2 solenoids ?
Old Nov 17, 2017 | 06:29 AM
Tugly's Avatar
Tugly
One starter relay on the fender, one solenoid on the starter. "Just clicking" is the relay engaging, but the solenoid doesn't receive enough juice to engage, and the starter doesn't have enough juice to crank... or other possibilities are at play.
Make certain you have good connection on both ends of each battery cable. The fastest/easiest way to check if this is a power problem instead of a relay/solenoid problem is to put a volt meter positive probe on the power side of the starter relay, and the ground probe on the engine block. Short the two large posts on the relay (engine clear, key out of the ignition) and watch your voltage. If it plummets during the click - bad connections to the batteries.
The overwhelming most common starter problem is bad batteries and/or bad connections between the batteries and the rest of the truck.
Old Nov 17, 2017 | 06:01 PM
hydro man 17's Avatar
hydro man 17
__________________________________________________ _____________________
A friend of mine that was a fleet mechanic for a lot of years told me that the first thing he checks with a finicky engine is the battery and cable connections. Quite often the end of fix.
Ford79
May 26, 2011 07:48 PM
dirty1
Oct 9, 2010 06:57 AM
IDPisan
Oct 6, 2009 01:43 PM
blackf3504dr
Sep 29, 2004 04:57 PM
kochy54
Jan 2, 2003 12:53 PM
