Unidentified light
Old Nov 12, 2017 | 08:44 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Unidentified light
Would anyone like to speculate the purpose of the light fixture "B" in the pictures below?
To put it into context, the connections in the boxes "A" go to gauges in the instrument panel. The light socket "C" is the high/low beam light.
The unidentified light is plugged into a 3-outlet plug. I don't remember where the other two went, but I can see they're scratched where something was plugged in to them. The schematic shows three instrument lights, but it doesn't show where they go. The panel itself only has holes for two.
It looks newer than original, as it isn't cloth wrapped. Radio maybe?
I know the truck had a "stem" type radio at one time. Someone had hacked holes into the dash with a chisel or something. It was rough. I can't imagine someone that would cut the holes like that would go the trouble of hooking up the light properly.
Thoughts?
Old Nov 12, 2017 | 09:13 AM
Smitty49's Avatar
Smitty49
I had shielded light on a cigarette lighter like that one but your lead doesn't look long enough to reach that area of the dash
Old Nov 12, 2017 | 10:33 AM
53 tonner's Avatar
53 tonner
Do you have factory blinkers? This may be one of two indicator lights in your dash.
Grant
Old Nov 12, 2017 | 10:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Parts catalog pic shows 4 bulbs (13466) in cluster.
9273 is the fuel gauge, 17255 is the speedo, 10850 is the generator gauge, 11572 is the ignition switch, 15055 is the lighter socket.
Old Nov 12, 2017 | 11:07 AM
firstrider's Avatar
firstrider
What yr. truck ? Socket type is for a dash gauge cluster light or speedo cluster light . Shielded type is for a back lit item , radio light or cigar lighter .
Old Nov 12, 2017 | 11:19 AM
NumberDummy
Originally Posted by firstrider
What yr. truck? Socket type is for a dash gauge cluster light or speedo cluster light. Shielded type is for a back lit item, radio light or cigar lighter .
OP has "1953 F100 Deluxe Cab" in his signature, why I posted a pic of the 1953/55 wiring.
Old Nov 12, 2017 | 11:38 AM
Mixer man's Avatar
Mixer man
I know some cars had a lighted ring around the ignition switch, but never saw any trucks with it. All of the radios that I know of are lighted internally, so no shielded bulb there. The only other two choices are, IMO, dispatch (glove) box, and cigarette lighter.
Old Nov 12, 2017 | 11:54 AM
Indybeer's Avatar
Indybeer
My 54 only has 2 instrument panel lights Here is a pic of it after rewire. The rewire kit was for a 53-56. Not sure where the third back light would go. My panel looks like the diagram Number Dummy posted.
Old Nov 12, 2017 | 12:06 PM
NumberDummy
Post #4 has the 1953/55 pic, here's the 1956 pic. Bulbs are Ford basic part numbers 13465 & 13466.
Old Nov 12, 2017 | 01:30 PM
56panelford's Avatar
56panelford
Did the ash tray have a light?
Old Nov 12, 2017 | 02:48 PM
bigwin56f100's Avatar
bigwin56f100
As others have already stated it is for the cigarette lighter well
Old Nov 12, 2017 | 02:53 PM
56panelford
Why would you have a light in the cigarette lighter well...? I'm confused..
Old Nov 12, 2017 | 03:04 PM
Indybeer's Avatar
Indybeer
Not sure why you would light it
Old Nov 12, 2017 | 03:40 PM
bigwin56f100
Everyone smoked back then. When you'd use the lighter at night it pops out and you need to be able to see where to put it back into the hole-well
Old Nov 12, 2017 | 03:48 PM
56panelford
Neither one of my trucks had a cigarette lighter so have no idea how it worked. Did that light clip onto the barrel the lighter inserted into..?
