Sponsored by: Real Truck
interior help
Old Nov 11, 2017 | 10:53 PM
Spokeo's Avatar
Spokeo
interior help
Hey guys I'm pretty new to the forums, and Im wanting some help. I'm going to be coming into contact with a 2011 6.7 XLT and I was wanting to update the gauge clusters/ radio to the 2013 lariat gauges and so on, im needing to know what I need and what to look at to start the build.
Old Nov 12, 2017 | 04:01 PM
Pocketlint's Avatar
Pocketlint
So you have a 2100 5.7 XLT and you just want to update to the gauges from a 2103 6.7 Lariat? Do you have all the parts that you are trying to swap? If you could be a bit more specific about what it is on the dash and gauge cluster you want to swap that would help.
From the sounds of it it looks like you want to swap the instrument cluster and just the stereo system. The more info you tell us the better the answer you are going to get
Old Nov 12, 2017 | 07:40 PM
Spokeo's Avatar
Spokeo
The instrument cluster yes, thats located in the middle of the speedometer & RPM, that tells the tirepressure, trailer info, and MPG to empty, along with the stereo radio i want to change it from the XLT to the Lariat Myford sync
Old Nov 12, 2017 | 07:48 PM
Pocketlint's Avatar
Pocketlint
does your current truck have sync? The other thing your going to need if you dont already have it is the steering wheel controls? What type of OEM stereo do you have in your current truck?
Your going to need to have the cluster mileage updated and I believe you need a flash done so your truck would work with the new dash cluster with the info center in it. Does the Lariat have a ford OEM stereo/navigation system? I dont know if the xlt has the connection in the steering wheel for the controls for sync, but you might be able to swap steering wheels/columns because I would assume the Lariat already would have the steering wheel controls.
I think it wouldnt be too hard to do, and I am sure there are fellas here who have done it that might be able to give you more info, but it's definitely doable
Old Nov 12, 2017 | 09:20 PM
Spokeo's Avatar
Spokeo
The XLT has the Line in not Sync, as for the radio it has it's the regular stock one and the steering wheel has the controls on it too the Lariat has the touch screen radio+ navigation
Old Nov 14, 2017 | 02:06 PM
wrvond's Avatar
wrvond
The interiors of the 2011 and 2013 trucks are essentially identical. Your problem is one of options. The XLT you have just has an LED information screen in the dash and the 2013 Lariat has the graphic information center.
What you are trying to do is similar to someone wanting to install power mirrors on a truck that came with manual mirrors.
It can work, but very often does not. Wiring harnesses are common between vehicles regardless of trim level up to a certain point, but key elements are not. For example, the computer that controls Sync has to be present or it's just not going to work.
It is possible that simply swapping the instrument cluster will give you some, or even most, of the functionality of the 2013, but unless you get the computer flashed, I can guarantee not all the functions will work.
IIRC there are companies that specialize in selling upgraded dashes, along with flashed computers. There are also companies that will flash your existing computer. None of that is cheap.
All you can do is give it a try and see what happens. If nothing works, you can always switch back and sell the 2013 hardware to get your money back.
Good luck!
Old Nov 22, 2017 | 11:24 PM
KlamathRiver's Avatar
KlamathRiver
Spokeo,
I looked into a upgrade of the instrument cluster on my 2016 XLT to a productivity screen without luck.
From what I've read older Super Duties are able to be upgraded:
https://www.ford-trucks.com/forums/1...n-success.html
I also looked into upgrading to a Sync 1 GPS Navigation Radio but it was a bit more than I'm willing to spend:
https://www.infotainment.com/product...iABEgJa5vD_BwE.
There maybe other options out there and people that know more than I do that can help with your questions.
ddunkle94
Jun 23, 2018 09:04 PM
Jimmyl21
Oct 17, 2017 07:22 AM
RUNVS
Sep 23, 2016 02:50 PM
nailerdog
Jan 1, 2011 12:42 PM
Danger_Dave
1983 - 2012 Ranger & B-Series
Jan 11, 2010 05:54 PM
