Windshield opening tabs
Old Nov 11, 2017 | 04:46 PM
firstrider's Avatar
firstrider
What was the purpose of them ? Met up w/ a buddy in Vero Beach at the Velde Ford car show . His '51 has the two tabs in place & makes the rubber seal protrude in the two places where the tabs are located .
Old Nov 11, 2017 | 06:43 PM
Doc's Avatar
Doc
Tell him to grind them off clean. Nobody has ever been able to give a good answer as to why they exist.
Old Nov 11, 2017 | 06:52 PM
moejr's Avatar
moejr
I think the tabs have something to do with attaching the SS windshield trim.
Old Nov 11, 2017 | 07:28 PM
firstrider's Avatar
firstrider
The tabs would be in the way if attaching the bright metal windshield trim .
Old Nov 12, 2017 | 12:33 AM
52 4x4's Avatar
52 4x4
My question on this would be, why didn't they interfere with the original seal, or the installation of the stainless trim on those equipped with them? I've never had my windshield out, but need to replace soon. - Bob
Old Nov 12, 2017 | 06:24 PM
bobj49f2's Avatar
bobj49f2
They serve no purpose IMO other than a place for rust to start and get in the way when removing or installing glass. If you look in the shop manual it will tell you to cut them off if installing the optional stainless trim. The trim itself does absolutely nothing to hold the glass in. I grind them smooth like Doc suggested.
Old Nov 12, 2017 | 10:58 PM
52 4x4's Avatar
52 4x4
I'll look for them when I change my windshield. Are you saying they wouldn't be there on a '52 that was factory equipped with the stainless trim? Mine just has the plain rubber seal. - Bob
Old Nov 13, 2017 | 11:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
They don't seem to be related to the SS trim, they were on 48-50's and deleted after that. It's hard to figure what possible use they were, but they make windshield installation a nightmare. A Dremel with cutoff disc will grind thru the spot welds quick enough.
Old Nov 13, 2017 | 01:08 PM
52 4x4's Avatar
52 4x4
Sounds like I won't need to worry about them. - Thanks, Ross!
Spparky82
Aug 18, 2018 08:57 PM
Spparky82
Oct 20, 2015 07:41 PM
Skalywag
Nov 14, 2014 07:13 PM
kenwright396
Apr 21, 2010 10:39 PM
newblder
Sep 12, 2008 01:18 PM
