1968 windshield trim
Old Oct 20, 2015 | 06:00 PM
Spparky82's Avatar
Spparky82
I replaced my windshield today and I am having a hard time putting the trim back on. Is there a easy way to put the trim back on? I was using soap and water. With no luck.
Old Oct 20, 2015 | 06:03 PM
ultraranger's Avatar
ultraranger
Rubber seal goes on the glass. Trim goes on the rubber seal. Trim, rubber seal and glass, as an assembly, gets installed into the windshield channel of the cab.
Old Oct 20, 2015 | 06:21 PM
Spparky82's Avatar
Spparky82
Can I install the trim with the windshield installed or do I have to pull the windshield out to put the trim on?
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Trim (stainless steel windshield reveal mouldings) are installed on the windshield weatherstrip first .. then the weatherstrip is installed on the windshield. There is NO other way to do it!
Old Oct 20, 2015 | 07:41 PM
f100today's Avatar
f100today
You must pull the windshield back out. Good luck and have extra hands. I put my seal on the glass then used tape to hold it in place. Wrap the tape from one side of the glass over the seal and on to the other side. As you install the the trim, peel back the tape at the section of trim you are installing then use it to hold the trim and seal on as you go. Two people is good; three people are great. Try and find someone that has done it before. That always helps.
GoldCo
Jul 24, 2017 02:57 PM
FordIowan
Jul 8, 2012 12:45 AM
CUSTOMIMAGING805
Apr 14, 2011 05:10 PM
jmadsen
Jun 2, 2010 11:24 AM
My Ford Truck
Mar 22, 2003 08:45 PM
