Fuel pressure question ....
Old Nov 23, 2017 | 09:45 AM
  #76
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by jstihl
sorry sous , I forgot to mention that I did that yesterday as well. I tried to line up the slots the best I could. It seems like the standpipe would go in no matter which way it was positioned like the slots wouldn't go down into the grooves of the bowl. I also checked the check valve by pushing down on the center of the standpipe . and it seem to be working properly. Should I take all the guts out of the check valve and try running it like that?
You could, but I don't think this is your problem. Baatzy had an issue where the slots were not matched up well and the truck would idle fine, but when fuel was called for the truck would fall on its face.
So, if you didn't have a fuel gauge you would not be able to tell a difference in the way the truck is running right?
What is the lowest PSI the pressure gets to in a towing or full throttle condition?
Are you using a 90 degree bend or reducer at all between the bowl and sensor?
I think that 45 PSI is the minimum that should be sustained, but could be wrong. I know Tugly has stated the PSI minimum many times, but I just don't have the time right now to look it up.
I really cannot think of anything else to look at. You could try doing a warranty claim on the sensor and see about getting a new one from AutoMeter. I know I had a problem with my sensor from ISSPro the first time around.
Grasping at straws here friend, and I don't know what else to ask about because you seem to have gone through the entire system already.
Old Nov 23, 2017 | 10:31 AM
  #77
jstihl's Avatar
jstihl
lol grasping at straws is right! I dont know where to go from here, it seems like i 've tried everything. Sender adapter is straight. Most of the time the farthest it will drop is to 50 psi, which I know it's probably fine for the truck but on occasion and very rarely I saw it drop down to 42 PSI. It always regains pressure very quickly, it's almost like the fuel gauge needle moves with the throttle pedal. If it wasn't for that and the gauge was acting more erratic I would think that the sender might be bad. Next time one of you guys are under your hood can someone please look to see if you have a crimp Mark like mine? That is the only thing I can go on right now, I'm pretty sure I have eliminated everything else
Old Nov 23, 2017 | 02:33 PM
  #78
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Crimp on the hard fuel line is normal. It is typically done for ease of installation, to keep the nut near the end of the line rather than sliding all over. Passenger side fuel line is the same. Not a worry, will not affect flow.
Is the fuel cap original? Maybe it requires a vented cap. Also on trucks with plastic tanks there is a vent hose that clips to the frame rail. The end has a plastic fitting that can become clogged. Just more straws to grasp at.
hawkco66
Aug 18, 2019 12:51 AM
timmyboy76
Apr 8, 2011 11:13 AM
jwheatley20
Dec 22, 2010 09:19 PM
BigJake34452
Sep 25, 2009 08:37 AM
cdiddy
20
Jan 16, 2008 02:14 PM
