Sponsored by: Real Truck
Front Camera
Old Nov 7, 2017 | 04:42 PM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Front Camera
Is there an OEM / Ford front Camera for a 2013? If so, anyone got a part number? I think it may be in the Ford emblem which I hope I can remove the non Camera emblem and add the OEM one
Old Nov 7, 2017 | 04:51 PM
seville009's Avatar
seville009
This thread tslks about a third party csmera for a 2012
https://www.ford-trucks.com/forums/1...mera-kits.html
Old Nov 7, 2017 | 05:16 PM
Just Strokin's Avatar
Just Strokin
The only trucks I am aware about with the front cam was the Raptor. You might check the F-150 forum to see if anyone there has and idea. Even if you add a factory style cam, you will probably need to use a LockPick to view it.
The 2011-2012 is a different radio setup than the 2013-2016.
Old Nov 8, 2017 | 05:03 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Thanks guys. Where I got the idea was from the LockPick site. I was reading through their install and set up documents where they mention in a few places a front Camera which by the way it read was programmed into the PCM. I haven’t checked ForeScan yet to see if there really is an on / off switch for a front Camera. Also used my best friend Google which didn’t turn up anything oem. I found a ‘knock off’ front Camera in the Ford emblem but it looked small like it was for the 150s. Thought I would ask here. Looks like I’m sol for that mod. At least an OEM one.
greatgreens
Oct 6, 2017 09:16 PM
NewXer
Jul 17, 2014 06:22 AM
cooljman1
Nov 7, 2006 08:37 AM
highboy390fe
15
Jan 10, 2006 05:13 PM
sullyda1
Dec 18, 2002 06:24 AM
