P20BA Reductant Heater A Code
Old Nov 6, 2017 | 08:44 PM
Ford Truck Dude's Avatar
Ford Truck Dude
I have a 2011 F250 with 44000 miles on it. I just go the dreaded P20BA code. I bought the Dorman heater assembly unit from Rock Auto and just installed it. Cranked it up and the check engine light and a wrench light are still on. Anyone have any input that may help? very frustrating.....
Old Nov 6, 2017 | 09:21 PM
cappa's Avatar
cappa
Full delete will make everything better
Old Nov 7, 2017 | 08:27 AM
Just Strokin's Avatar
Just Strokin
Did you clear the codes? Some codes require you to use a code reader to erase from the PCM.
Some codes require a drive cycle to clear from PCM even if the CEL light is off.
Old Nov 8, 2017 | 07:39 PM
Ford Truck Dude
No, I didn't clear the codes. I'll try that. Do you have the steps to perform the drive cycle?
Old Nov 8, 2017 | 09:13 PM
J ballan's Avatar
J ballan
How hard was it to install? I have the same part ordered for mine and was planning on changing it this weekend.
Old Nov 8, 2017 | 09:44 PM
Ford Truck Dude
It wasn't that bad. The hardest part was reaching on top of the tank to disconnect the harness. Make sure you give yourself some slack in the injector line that runs to the exhaust on the passenger side. Pop the tabs that hold it in place, this will let you lower the tank and unhook it from the fitting on the pump.
Old Nov 15, 2017 | 11:35 PM
Ford Truck Dude
Smile
so I did the drive cycle and the wrench light cleared. I ponied up and bought a code scanner that has the erase code feature and the code cleared. Truck runs great and is reading the DEF level again on the dash.. Thanks for the insight. Let me know if anyone needs some help with the install and clearing, be happy to save anyone the pain of going to the dealer for a runaround.
Amicus
Mar 31, 2017 11:53 AM
fordguy4life
1997 - 2003 F150
Jul 18, 2010 04:05 PM
lucky13
1997 - 2003 F150
Oct 15, 2007 09:54 AM
Jim59
Oct 21, 2005 05:07 PM
gnfshn1218
Bronco II
Oct 27, 2003 01:42 PM
