Water pump failure
Old Nov 2, 2017 | 04:12 PM
Jarkill's Avatar
Jarkill
Water pump failure
Well, water pump started leaking from the weep hole and I have an 85 mile drive home. Any bets on me making it?
Old Nov 2, 2017 | 05:42 PM
tecgod13's Avatar
tecgod13
How fast is it leaking?
If you take you take your time and stop to dump in water as needed you should be fine.
I made it home once when it was leaking so bad it was coming out almost as fast as I poured it in. Had to stop for everything to cool off partway home, but more or less made it with only like half of the coolant that's supposed to be in there.
Old Nov 2, 2017 | 09:49 PM
Impreza_gc8's Avatar
Impreza_gc8
If you keep it topped off you'll be alright.
Old Nov 2, 2017 | 10:04 PM
wtroger's Avatar
wtroger
Don't lock the rad cap down. That will keep the pressure off. If it just weeping it will go a long way..
Old Nov 3, 2017 | 09:37 AM
Jarkill's Avatar
Jarkill
Didn't risk it. It was leaking too fast. Ended up changing it in the parking lot at work. Finished at about 10:00 at night ha! Kicked my a$$!
Old Nov 3, 2017 | 03:05 PM
Impreza_gc8
You swapped water pumps in the middle of a parking lot at night? Including removal of the reverse threaded fan clutch? If so, big respect to you sir.
Old Nov 3, 2017 | 06:11 PM
jmuenchow's Avatar
jmuenchow
x20000
lol
Old Nov 4, 2017 | 11:36 AM
Macrobb's Avatar
Macrobb
That's still pretty good. Props to you!
I've replaced water pumps on these several times, but never in a parking lot, and it was *still* a real pain.
Old Nov 6, 2017 | 08:52 AM
Jarkill's Avatar
Jarkill
Thanks for the props y'all. I have a wheel barrel compressor and a large assortment of tools in my truck at all times. It wasn't like I was turning bolts with rusty pliers I found in a ditch or anything haha! I got the fan removed with my air chisel and had spill pads and a bucket for the coolant. The thing that sucked is that I only had a small mag light that I had to hold in my teeth for the final part of re assembly. Got dark quick!
Epd444
Apr 26, 2012 11:18 AM
racerx179
Jun 1, 2010 11:20 PM
crazer42
Nov 26, 2008 07:58 AM
firebug
Aug 5, 2004 09:04 PM
RockinB
Dec 22, 2003 10:04 PM
