tailgate problem
Old Nov 1, 2017 | 07:19 PM
donthekawguy's Avatar
donthekawguy
tailgate problem
I finally got my truck back today and got excited and put the tailgate on that I just picked up last week. Well after adjusting it I slammed it shut pretty proud of myself for getting it lined up on the first try. Well I went to open it and the handle is really hard to move and the rods that pull the locking tabs are disconected. Any idea how to open it up?
Old Nov 1, 2017 | 08:18 PM
HIO Silver's Avatar
HIO Silver
The rods are either disconnected at each latch or disconnected at the handle.
50/50 odds.... I'd remove the handle assembly first since both are affected. I have a dent and bumps.... one of 'em has an access panel.
Old Nov 1, 2017 | 09:04 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Take 2 flat tip screwdrivers and carefully pry (from inside the bed) the locking pieces 431D76 back in the t/g body/latch.
While you are pushing the t/g closed to take some pressure off, this works better with 2 people.
Then it is 431A78 rod fishing time. A metal coat hanger works pretty good, after you flip the t/g upside down on its long axis edge, to get the rods closer to the handle.
I bet your plastic rod retainers 431C56 are broke.
Old Nov 2, 2017 | 01:32 AM
donthekawguy
PERFECT! Thats what I was needing. The rod going to the left side is hanging there with no clip. I haven't gotten around to looking for the right one yet. I think I'll leave it alone until I get the clips. Thanks!
Old Nov 2, 2017 | 11:03 AM
77&79F250's Avatar
77&79F250
If you look close to the last pic you can see a home made retainer out of a piece of sheet metal and some RTV on the lower rod.
Old Nov 2, 2017 | 11:29 AM
JakeHan's Avatar
JakeHan
If you have skinny fingers, you can get the lower one back into it's hole right in place, and open the tailgate normally.
Old Nov 3, 2017 | 10:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The tailgate rod clip (1973/96 same & R/L same) is available in the "help" section of auto parts stores and is also the same as the door lock cylinder rod clip of 1973/79 F100/350, 1974/78 LTD/Grand Marquis, 1979/91 Crown Vic/Grand Marquis, 1983/91 Ranger tail gate and etc.
Old Nov 3, 2017 | 11:12 AM
77&79F250's Avatar
77&79F250
You mean 21952?
File Type: pdf
Old Nov 3, 2017 | 11:36 AM
NumberDummy
You mean 21952?
Yes.
E6AZ-5421952-A replaced D4AZ-6521952-A & E3TZ-1021952-A
Look up the tailgate clip basic part number of 431C56 in the 1973/79 truck catalog and you'll see it says refer to basic part number 21952.
The C/D catalog that was scanned from the 1980 edition that most everyone is using, shows the D4AZ number, but not the replacing part number of E6AZ.
However, if people have the final edition of 10/1988 (only available on microfiche), it does show the E6AZ number.
The only member of FTE that I'm aware of that has this catalog is...
Old Nov 3, 2017 | 12:30 PM
77&79F250's Avatar
77&79F250
Thanks. Yes when I need one for my tailgate rod, I went to my parts trucks doors and got one.
Old Nov 3, 2017 | 01:50 PM
Aaron-71's Avatar
Aaron-71
Excellent write-up guys. I was looking for something like this ages ago, but haven't had to open my tailgate in a long time.
Mine is also stuck lol.
bloodspoint
Jul 5, 2012 06:49 AM
gandalf23
Mar 3, 2012 09:56 AM
ejolliffe
Paint & Bodywork
Feb 18, 2011 09:17 PM
xirxious
Aug 22, 2009 03:59 PM
1973FordF100
Oct 28, 2008 02:05 PM
