Tailgate Problem
Old Jul 6, 2007 | 09:34 AM
ejolliffe's Avatar
ejolliffe
Tailgate Problem
I have a '78 F150 and the tailgate is really hard to open. The latch looks a little tired. The problem is on the passenger side the piece that is hooked to the end of the rod and actually keeps the gate from falling back open (the edge looks like a chisel) doesn't seem to want to retract all the way. I am using a screwdriver to 'pop' it out of the latch hole in order to open. Do I need a new latch, do I have a bad rod or am I down to getting a whole new tailgate? Any direction would be great!
Old Jul 6, 2007 | 12:40 PM
warthog5's Avatar
warthog5
Open the tailgate and remove the inspection panel on the inside of the gate.
Now you will be able to see where the problem lies in the linkage.
Old Jul 7, 2007 | 02:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/79 F100/350 Tailgate Mechanisms
Styleside tailgates use the same R/L latches, arms, hinges, strikers, rubber bumpers = 1964/79.
Only the handle and rods are different. The handle and rods are the same 1973/79.
If by pulling the handle, the right side latch doesn't release, it may be because the CLIP that holds the rod to the handle has broken. There are two clips, one right, one left. Both are the same part number.
This same clip fits 1973/1991, all F Series Styleside tailgates.
E3TZ1021952B .. Clip = Rod to Handle (replaces: E3TZ1021952A)
Still available from Ford = List Price = $2.00
Old Feb 17, 2011 | 08:40 PM
kensamp's Avatar
kensamp
Tailgate Problem
I have a Ford 1994 F-150 XLT
I BROKE the Handle off of the Tailgate ....
Now I Cannot open it - SUGGESTIONS PLEASE!!!!! rolleyes:
Please advise - locksmithken@yahoo.com
Old Feb 18, 2011 | 07:06 AM
warthog5's Avatar
warthog5
Have you taken the inspection panel off the inside of the gate? Have you looked in there.
Sounds like a new handle and some maintenance lubing all the working parts in there are in order.
Old Feb 18, 2011 | 11:20 AM
kensamp's Avatar
kensamp
Tailgate Problem
There is NO access or inspection panel there - NONE - that is not the answer -
Screwdriver will not open it - there is no acess panel - nothing to grab onto ..
Need more suggestions.....
Old Feb 18, 2011 | 02:55 PM
warthog5's Avatar
warthog5
Don't know what to tell you. Here is the access panel on mine.
Old Feb 18, 2011 | 09:17 PM
Action4478's Avatar
Action4478
If you have a ford , there are bolts on the inside of the TG that hold the handle in place .. Look closely from the outside under the handle , you will see the clips & the mechanism that opens the latches ...
KsCop
20
Sep 11, 2014 10:13 PM
1999er
Jul 24, 2014 05:27 PM
Mr. Green Jeans
Mar 30, 2010 07:14 AM
jasond5150
Aug 6, 2008 09:48 PM
78sharpshooter
Jun 29, 2007 04:11 PM
