Pull VSS Sensor and Found THIS!
Old Oct 31, 2017 | 07:09 PM
beefey's Avatar
beefey
Is this cause for alarm? It appears the vehicle speed sensor has metal flakes on it.
I was throwing C1229 -- Rear Wheel Speed Sensor Coherency Failure
I also snapped one of the ears off the plastic plug. Does the plug need to be replaced or have you guys ran dirty with one and it's fine?
On an unrelated note-- does the VSS actually report the speed to the speedometer? My speedo is functioning fine...
Old Oct 31, 2017 | 08:42 PM
HD Rider's Avatar
HD Rider
Just judging by the yuck on it, I would pull the cover at least to change the gear oil.
Old Oct 31, 2017 | 09:15 PM
Colorado350's Avatar
Colorado350
X2. Just replace it, I think mine was around $30. If you do pull the cover buy a LubeLocker gasket, no mess and reusable.
Old Nov 1, 2017 | 07:02 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
x3 on new fluid. I used RTV type sealant, but I was doing both the front and rear at the time and was not aware of the gasket available. This was a week after I bought the truck and if/when I change the fluid next time I will use the gasket.
Old Nov 1, 2017 | 07:48 AM
Walleye Hunter's Avatar
Walleye Hunter
If you just broke one ear off that connector you could be good with it, I have a few in use that way. If you broke both ears you'll need to replace it or hold it in place with another device, maybe a wire tie would work. If you hook it up and it comes apart you'll notice it in your speedometer, cruise control and your abs light will light.
Old Nov 1, 2017 | 01:14 PM
beefey's Avatar
beefey
So can this part go bad even IF my speedo seems to work fine?
Old Nov 1, 2017 | 01:40 PM
Walleye Hunter
I had one light my ABS light but everything else worked fine. I have read on here that sometimes you can clean that sensor and it will work but I have never done it.
Old Nov 6, 2017 | 01:31 AM
beefey's Avatar
beefey
Replaced the sensor. Still have the code and the light :/
The truck makes a strange gargle sound on key turn and then the ABS light comes on. It makes me think there may be some air in the ABS pump...
I had a brake line blow out a while back when this all started. I wonder if air got in there....
Old Nov 6, 2017 | 06:43 AM
Walleye Hunter
There is a thread around called "What's that growl?" or something similar. It's not a rare occurrence. Did you clear your light? You might have to clear to get that to go out.
Old Nov 6, 2017 | 10:13 AM
beefey's Avatar
beefey
Yeah I cleared it with the computer and it just immediately returns...
I also changed the fluid just in case there was metal in it causing some issues.
ExpySport
Mar 3, 2009 04:04 PM
urcysk
Nov 19, 2008 06:52 AM
maverick1701
Oct 6, 2008 09:33 PM
djtech
Jul 20, 2006 08:32 PM
scooter_1968
Dec 15, 2003 02:07 PM
