Broke off speed sensor
Old Nov 15, 2008 | 08:41 AM
urcysk's Avatar
urcysk
Ok so I was trying to change the speed sensor cause the tranny won't shift and the speedo won't work also ABS light is on. But I broke it off in the process can I punch it out from inside the diff its broke off flush with the diff I have a 1991 f250 4x4
Old Nov 16, 2008 | 09:24 PM
acrozier's Avatar
acrozier
Hopefully you can. I had the same thing happen on mine. Except mine is a 97 and the sensor is on the front side of the pumpkin. I had to push the remainder of the sensor down into the diff and fish out the pieces with needle nose pliers. Not alot of fun. If the sensor is on the back of the diff, you should be able to pull the cover drain the fluid and pull it out. A messy job, but it should be doable.
Old Nov 19, 2008 | 06:52 AM
urcysk's Avatar
urcysk
Thanks for your help i was able to push it through it with an air chisel that broke the magnet and it all came out in pieces but at least it out I also found out after its just an ABS sensor speed sensor is on the rear of the transfercase but thats ok I needed to change that anyway
mark227
Dec 20, 2015 07:17 PM
Mountainwolf69
Mar 25, 2015 10:08 AM
calvinbabb
Dec 18, 2014 04:21 PM
wingnutt2420
Jul 1, 2010 06:41 AM
JohnnyAirtime
Jan 4, 2010 01:47 PM
