Transmission slipping?
Old Oct 28, 2017 | 07:57 PM
Isaiah99's Avatar
Isaiah99
I was offroad going up an small incline that was uneven. As I was going up I heard a quiet grinding type of noise and could feel it on the pedal, then it started to slip and i had no power until i put it into neutral and rolled back down. I was then able to move over and was able to make it up without any grinding noise or slipping where the ground wasn't uneven. I don't have any slipping on road even under hard acceleration. Could it be the transmission separating from the engine when the vehicle twists?
Old Oct 28, 2017 | 09:36 PM
wedge542's Avatar
wedge542
Flashing the tow haul any? Look under trans,see if it looks like been moving around on rear mount,ck for a gap at bellhousing,any leaks,trans temp change?
Old Oct 28, 2017 | 09:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Only if all of the transmission to engine mounting bolts are very, very loose.
Old Oct 28, 2017 | 10:34 PM
Isaiah99's Avatar
Isaiah99
I dint notice it flashing. Doesnt look like it has moved, no leaks and full of fluid, and the temp was normal.
Old Oct 28, 2017 | 11:58 PM
FiznUKa's Avatar
FiznUKa
Was your transfercase engaged fully? How about your hubs?
Old Oct 29, 2017 | 12:24 AM
Isaiah99's Avatar
Isaiah99
I was in 2wd. The hubs have a center cap over them so im not sure what they are set on.
Old Oct 29, 2017 | 12:32 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Rear Differential is my bet. Time to pull the plug out and have a look.
Old Oct 29, 2017 | 01:37 PM
87crewdually's Avatar
87crewdually
If it only occurred when you were hanging a back wheel from the uneven ground it may of been the limited slip differential slipping. If the clutch discs are wore it can act like an open diff and put all the power to one wheel. The power will go to the path of least resistance which is the tire with little to no traction causing the lack of propulsion at that point.
Pulling the plug will tell you little to nothing since they are fiber discs and non-magnetic. If you suspect clutches you need to at least pull the rear cover for a look.
But if you heard clunking and grinding I have seen clutch packs wore so bad that it allowed the spider gears to jump teeth on the side gears. If it did it enough you may them see metal on the plug due to damaged gears.
Either way you can buy a kit to rebuild it.
Old Oct 29, 2017 | 03:13 PM
Isaiah99's Avatar
Isaiah99
​​​​​​I don't think it's the differential because It still made that noise when I wasn't moving.
Old Oct 29, 2017 | 04:01 PM
Isaiah99's Avatar
Isaiah99
It has an open differential and I stopped and got out to see what the noise was because at first I thought it was the fan rubbing on something, so the noise was still there when I was in park.
Old Oct 29, 2017 | 04:33 PM
Isaiah99's Avatar
Isaiah99
This is the only situation where it makes the noise and slips.
Old Oct 29, 2017 | 04:36 PM
wedge542's Avatar
wedge542
Are you locked in 4 wheel drive? can you tell if noise is engine area,rear end area?
Old Oct 29, 2017 | 05:37 PM
Isaiah99's Avatar
Isaiah99
​​​i was in 2wd. It sounds like it's right under my feet by the transmission.
Old Oct 29, 2017 | 05:55 PM
Isaiah99's Avatar
Isaiah99
I was in 2wd. It sounds like it's coming from the engine/transmission area
Old Oct 29, 2017 | 05:57 PM
wedge542's Avatar
wedge542
maybe if you can replicate the same while its making that noise, let it run and get out and ck see where.
