Transmission slipping?
Old Oct 30, 2017 | 02:04 PM
Isaiah99's Avatar
Isaiah99
Originally Posted by wedge542
maybe if you can replicate the same while its making that noise, let it run and get out and ck see where.
i couldn't tell exactly where it was coming from. I thought it sounded like it was coming from the turbo at first, but that wouldn't cause it to slip.
Old Oct 30, 2017 | 03:28 PM
olfordsnstone's Avatar
olfordsnstone
Maybe transfer case?
Old Oct 30, 2017 | 04:51 PM
Yahiko's Avatar
Yahiko
Both the Transfer Case and the Rear Differential are easy to check.
Drain the oil and see what comes out. If you find fragments you have problems.
Old Oct 31, 2017 | 12:07 AM
olfordsnstone
Failing 4x4 motor?
Old Nov 1, 2017 | 12:29 PM
Isaiah99's Avatar
Isaiah99
I'll take a look at the transfer case and differential when I get back home.
Originally Posted by olfordsnstone
Failing 4x4 motor?
How would I go about checking the motor?
ZooDad
6.7L Power Stroke Diesel
Oct 6, 2017 02:49 PM
DarrellinCeres
Oct 19, 2012 01:11 PM
joshofalltrades
19
Jun 7, 2012 07:39 PM
astone
1997 - 2003 F150
Oct 9, 2006 07:20 PM
Picnic
17
Feb 2, 2005 12:07 PM
